Electronic Vs. Manual 4X4 engagement??
Old 12-09-2003, 11:53 PM   #1
In a '95 - '96 2-door Blazer, was there either electronic or manual 4X4 engagment, or are all 2nd gen's electronic??
Also, which one is more reliable?
Thanks,
Old 12-12-2003, 09:28 PM   #2
GMtruckHQ
kevincolin's Avatar
I know 97 has Electric not sure about reliabilty / year numbers,
Old 12-12-2003, 10:06 PM   #3
Insane Network Engineer
rlith's Avatar
I believe 93 to current only had the electronic version (I could be wrong)
Old 12-13-2003, 09:49 PM   #4
GMtruckHQ
kevincolin's Avatar
If thats the case then Electronic would be much more reliable
Old 12-15-2003, 12:22 AM   #5
CHANGE YOUR EMAIL ADDRESS
Manual is more reliable. However, electronic is convenient, isn't it?
Old 12-15-2003, 01:34 AM   #6
SWTexasBLAZER's Avatar
manual is more reliable....basically, anytime you throw electrical crap in anything, there is a higher chance of something not working. often with say pushbutton 4x4 engagement, you pretty much just assume it went into 4wd when you hit the button. with manual, when you shift it into 4wd, you will know it if it does not go into gear right away.
Old 12-23-2003, 08:01 PM   #7
ForestGreen4x4's Avatar
I know i'm new here but my mom has a 96 that comes with the manual engagement, but my 96 lt i just got has the elec. But i would have to agree with SWTexasBlazer that the manual is more reliable.
Old 12-24-2003, 04:34 AM   #8
V8 Member
the_dubster98's Avatar
well the mechanical isnt all that great either, you may engage the transfer case but there is still a locker type thing in the front that relies on vacuum.
Old 12-29-2003, 11:51 AM   #9
Autocross'n Member
zq8jeff's Avatar
I've seen a 95 Jimmy with the manual setup.But my 96 has the push button.I prefer the manual,I feel like I'm actually doing something when I pull back on the shifter.The button is just too easy,it takes the fun out of 4wheelin.
