Drop on 97 4wd 4dr
Old 07-25-2009, 12:32 PM   #1
Drop on 97 4wd 4dr
I have 97 4dr 4wd blazer. It is in the mist of possibly being turned into a 4dr extreme. Either way I want to go lower than the 2/2 drop I have now(backed out torsion keys and blocks). I know you can get the 3/3 belltech kit with new keys and leafs, but I would like to know if I can go 4/5 by adjusting the belltech keys once they are in and put in my 2in blocks with the 3in leafs?
Old 07-27-2009, 01:16 AM   #2
MVP
FireBall's Avatar
Re: Drop on 97 4wd 4dr
Hello, I've just recently been looking into this. If you use the search bar and look for "lowering a 4wd" you will find a bunch of useful info. There is always flipping the torsion bar and I believe that will get your front down between 4/6 inches.
From what I've read, I personally was scared to go lower because of the extensive wear on the front end parts when you go lower than just the keys up front.
If you can't find what your looking for here, check out blazinlow.com . They also had some useful info.
Get some pics up!!
Page generated in 0.92808 seconds with 31 queries
[Output: 43.40 Kb. compressed to 41.79 Kb. by saving 1.62 Kb. (3.73%)]
