Driving lights don't work on 02 blazer.
Old 03-30-2008, 04:25 PM   #1
Found a strange bulb with 4 wires coming off it for a towing connector (I assume as I can't think of anything else for that) that got jacked the day we got it.
Well needless to say the exposed wires shorted something out, but what?
Brake light works, signal works, but no driving light.
I checked fuses and they're all ok, so I replaced the bulb with one from my own that I know works and still nothing.
Anybody can point me in the right direction?
Is there another fuse block I'm missing? Burnt relay? Any fusable links?
Old 03-30-2008, 04:37 PM   #2
The Dreamsicle
cpolaris502's Avatar
Re: Driving lights don't work on 02 blazer.
you've got the fusebox that is on the left side of the dash and then the one on under the hood on the left fender.
you're talking about the daytime headlights or the running lights that go on at night?
Old 03-30-2008, 11:59 PM   #3
The rears when you turn on the headlight switch one click.
Old 03-31-2008, 03:02 AM   #4
I forgot to say its just the drivers rear light only. All others work fine.
Old 04-02-2008, 03:48 AM   #5
Fuses are good.
Old 04-02-2008, 05:06 PM   #6
Mr. Sparkle
Onimun's Avatar
Trace the wires upto the front. make shure its not cut off somewhere.
Old 04-03-2008, 12:32 PM   #7
do you have power at the socket. if not then start tracing the wires and probing to see where you lose the power at.
Old 04-08-2008, 03:04 AM   #8
I figured theres no power at the sockets at all. Thing is...this u-haul bulb is in both sides, lower socket, one side is still intact, so I put a normal bulb in. Looks as though the other side (drivers side) was ripped out while shutting the tail gate. DOH!
So I'm very thrilled to go poking around now
Was hoping for a secret fuse or something that would go out on a running light specific side
Thanks for the help guys. I'll be poking around this weekend.
Old 04-08-2008, 11:00 AM   #9
The Dreamsicle
that sucks, tacking down wires is no fun. good luck.
Old 04-09-2008, 02:54 AM   #10
I had no idea GM came up with the brilliant idea to have 3 (or is it 4?) fuses for driving lights. So I guess I skipped over a certain problem fuse...durr.
I combat that fuse with the GAGE on the dash misspell. HA!
Problem fixed
perhaps I should check each fuse individually...
Page generated in 0.57453 seconds with 31 queries
[Output: 69.03 Kb. compressed to 64.64 Kb. by saving 4.39 Kb. (6.36%)]
