The driver's side window on my 97' blazer quit working a few days ago. I pulled the door panel to see if any connections had come loose. Everything looked fine. Is there a way to tell if the motor went bad, or if it's the switch? Thanks.
Re: Driver's side power window is defunct.
Nevermind, I went and bought a motor with the option of returning it, and it turns out that the motor was the problem. Thanks.
sometimes hitting the motor with a hammer will temporarily repair any loose connections, allowing you to close the window if it starts raining
I need to replace mine. Do i need the regulator with it or just the motor?
you can replace the motor and the regulator or just the motor but if its the original you are still gonna have to remove the rivets from the regulator and take it out in order to get to the rivets on the motor so you canremove it from the regulator. hope this helps
