Door swap question
I did a search but could not find my answer but I may also be in the wrong section. Does the front door of a 4 door Blazer / Jimmy / Bravada, fit an S10 Standard cab truck? I was thinking that a 2 door Blazer will swap with a P.U. but when I measured the length of the 4 door Jimmy against the door on my 2 door Jimmy, the doors are the same length.
I've always had fullsize trucks and the smaller ones are a whole new ballgame. I also have a new found respect for you guys that tie into the Blazers and redo them. I've never seen more nuts, bolts, clips in a small vehicle in my life. A whole new learning experience in dismantling one, finding what fastener is where. So KUDOS to you all. |
You...Tonight
Re: Door swap question
yeah all the doors are the same i do believe
Should be the same
ZQ8 Blazer
98+ are the same while 95-97's are the same. The doors from these years will not interchange. All doors are the same on the s10 platforms.
correct me if Im wrong. They are interchangeable, but if you are going to swap the doors from 97 below to 98 plus you also need to swap door panels .. which in my opinion would be a nice upgrade from 97 and below .. |
