door panel question
Old 09-21-2007, 11:13 PM   #1
door panel question
I have a 4x4 Jimmy 4dr. I'm taking the door panels off to replace the speaker. How many screws are there holding the door panel on? I took out the one behind the handle, but something in the middle is still stuck. Any one know if I should just pull harder or if there is another screw somewhere that I'm missing?
Old 09-21-2007, 11:24 PM   #2
Classifieds Nazi
2dxtreme's Avatar
Re: door panel question
what year jimmy is it?
Old 09-22-2007, 01:29 AM   #3
forum idiot
orangesonoma's Avatar
it is a 98 jimmy right???
well then...here you go!
i made this just for you...
first locate and remove the two 7mm bolts under the arm rest
next remove the one phillip head screw on the door handle trim
next step is to remove the trim from the door grab it by the front of it and unclip it
now do not remove this from the door panel...there is no need to remove it
if your truck has power windows lift up the front and unclip the switch panel
next unclip the plugs...if you have a hard time with these clips...just slide the switch panel thru the hole in the door...
now pull the door panel towards you...if you cant get your fingers behind the panel...use a panel popper and release the white clips on the panel
and that is how you remove the door panel...you can use this if you need to remove the panel to change the speakers...
if you have manual windows you will need to remove the clip behind the crank...i use a hook pick to remove the clip...just use caution that the clip does not fly out...or you can lose it...once i get pics of that i will post it up...
any questions...pm me
http://www.s10forum.com/forum/f200/h...s-98-a-207452/
Old 09-22-2007, 03:05 AM   #4
BanginJimmy's Avatar
thats a better tutorial than some of the ones I've seen on here for bagging a truck.
Old 09-22-2007, 12:21 PM   #5
forum idiot
thank you!
Page generated in 0.58191 seconds with 31 queries
[Output: 55.49 Kb. compressed to 52.77 Kb. by saving 2.72 Kb. (4.91%)]
