Disc Brake Rear End info needed...
Old 08-24-2005, 12:50 AM   #1
Registered Loser
nmitchell86's Avatar
I figured I'd try you SUV kids. I did a search and found nothing so here is my question...
What is the RPO Code and GM part Number for a S-Series 2WD SUV rear end with an 8.5 ring gear and 3.42 gear ratio? I'm looking for the unit with disc brakes.
I want to swap it in to my S-10 pick up/ upgrade from Drum rear brakes.
Old 08-24-2005, 04:31 AM   #2
4DOOR4x42004's Avatar
Re: Disc Brake Rear End info needed...
GU6 is the code for the 3.42s. That will be on all rear-ends 2wd or 4x4.
I don't know the code for disc, I think that depends upon year model.
Old 08-24-2005, 05:35 AM   #3
Registered Asshole
Lowsonoma03's Avatar
i dunno the code for disc either, but look for them in 98-newer blazers...my 96 blazer 4dr 4wd has drum brakes in the rear....
Old 09-08-2005, 11:16 PM   #4
dropped99jimmy's Avatar
you can buy the disc conversion as long as you have the bolt on backing platers for the brakes
Old 09-08-2005, 11:54 PM   #5
CenTex's Avatar
Look on ebay, S10warehouse sells the complete rear end with the discs..
Old 09-22-2005, 01:25 AM   #6
Speed Guru
Insomnya3AM's Avatar
Florida pickup only tho Just bought a ZR2 Blazer rear end with discs for a buddy on eBay for 416.00, complete with new calipers, pads, rotors. score!
Old 09-22-2005, 12:58 PM   #7
Master of Tech
llawmaster's Avatar
So is the rear end on a Blazer/Jimmy the same as S10/Sonoma???
Old 09-22-2005, 01:12 PM   #8
Center your wheels!
layinbody31's Avatar
if you're looking to find a 8.5" rear with discs AND 3.42 ratio you are really narrowing your search down A LOT.
As far as I know, the 2wd disc rear ends only came in 2 door blazers ('98 up I think) that had either the ZQ8 package or the Xtreme package. There were lots of 4wd disc rears in the ZR2's but those are wider than the 2wd axles and therefore wouldn't fit.
To get a 8.5" rear in those blazers, it had to be a 4.3 with a 5 speed.
And then I believe you had to special order it with a 3.42 ratio (although I could be wrong on that).
So if you want to find one you'll have to find a '98 up 2wd 2dr blazer (ZQ8 or Xtreme) with a 4.3 and a 5 speed. Then I guess just verify that the blazer that it came from has the GU6 code.
Old 09-22-2005, 01:39 PM   #9
TrailBlazin'
SuperSS27's Avatar
Just picked up that exact rearend for 500 bucks. It was brand spanking new too...:-D Its going in this weekend.
Old 09-22-2005, 01:42 PM   #10
Same Poop,Different Scoop
devilman13xx's Avatar
my 4 door has rear discs, pretty sure all 98+ blazers have em, as far as gear i dont know
Page generated in 0.57474 seconds with 31 queries
[Output: 70.33 Kb. compressed to 65.79 Kb. by saving 4.55 Kb. (6.46%)]
