Differential cover
What size differential cover do I need to get for my 02 Blazer (was Xtreme, kits off)?
And is there an advantage to spending money on one... like the aluminum ones at Summit? I don't know shit about my differential, except that my cover is messed up. Also, changing one... what's the process? Just bolt on? I mean... I'm afraid of oil and what not |
forum idiot
Re: Differential cover
little elves might come out and knaw on your nutsack if you wear shorts...so make sure to wear long pants and tuck your pants into your sneakers so they can not crawl up...lol
i believe it is a 7.5 and yeah un bolt and remove all the old gasket...add new gasket make a gasket....bolt down new...then fill with gear oil Last edited by orangesonoma : 08-03-2007 at 11:03 PM. |
SmartTrak FTW
i believe if your looking at the cover from behind, a rounder shaped one is 7.5 and a little more squared is 8.5. mine is a 8.5 because its a 5spd. it talks about it a little in the 3/5 link how to on the home page of the forum. but why do you need a new one?
Mine is rusted and looks like something hit it pretty hard... and I was interested in a chrome one.
Honest Abe's Fab Shoppe
7.625
the 7.625" differential has a squarish cover the 8.5" differential has a roundish cover. my truck (8.5" ring gear): ![]() |
Thanks Ryan
![]() So, any reason to not get a chrome one and opt for an aluminum one? Don't really know what purpose the cover really serves |
Enthusiast
The diff. cover has many purposes. Prevent housing flex and cool the fluids. The f-body guys like to use TA diff. covers to help their 10-bolt last a little bit longer before upgrading to a 12-bolt or a nine inch. About the TA covers, they come in aluminum, adds strength to the case and provides support to the bearing caps.
Stock
x2. i'd go ahead and spring for the aluminum cover if you do any spirited driving. |
Spirited = ?
I launch from red lights... just a bad habit... don't know if you'd call that spirited driving |
no longer has a 95
I would also try to find one with a drain plug and a fill plug. The original fill plug is so hard to get out and there is no drain plug. It would make it a lot easier to change your fluid.
