difference in 2wd and 4wd
Old 02-12-2007, 02:29 AM   #1
bowtie99's Avatar
Question difference in 2wd and 4wd
i have fount a couple of sets of extreme wheels and zq8 wheels for the blazer but the seller tells me they will not fit cuz of my truck being 4wd. Can someone explain the difference in the why these will not fit my truck when both are 5 lug hubs...
Old 02-12-2007, 02:38 AM   #2
/\/\ ! /\/ ! |_!F3
NailZ's Avatar
Re: difference in 2wd and 4wd
different width of the center piece
Old 02-12-2007, 05:58 PM   #3
BlackEnvyDubz's Avatar
Ok its in the offsets like the 4x4 the fronts a high off set like a fwd car the back a normal truck offset like you 2wd s10
Old 02-14-2007, 07:48 PM   #4
Molon Labe
BudRacing's Avatar
basically, they'll mount, but they'll stick out 2" from where they should be
Old 02-15-2007, 10:20 PM   #5
bowtie99's Avatar
ok, so wat u r sayin is they'll mount, Are the front gonna stick out further then the back or are all four wheels going to stick out the 2 inches?????
Old 02-19-2007, 02:47 PM   #6
LOWBLAZERO1's Avatar
ALL 4
Old 02-19-2007, 10:32 PM   #7
Fourstringsquire's Avatar
the 4wd trucks have a +40 offset which means that the hub mounting flange on the wheel is 40mm from the center of the wheel twords the outside of the wheel. The 2wd have a 0mm offset which means that the hub mounting flange is right in the center of the wheel. So if u mount 2wd rims on a 4wd the wheels will stick out 40mm or 1.57". I have seen 2wd rims on a 4wd and it looks very bad in my opinion.
Old 02-19-2007, 10:56 PM   #8
Molon Labe
BudRacing's Avatar
Get corvette wheels instead, they look better anyway. they'll bolt right up without spacers
Old 02-19-2007, 11:05 PM   #9
bowtie99's Avatar
exactly what year vette are you talking about... Personally the zq8 rims for the s-series are some of the best looking stock rims i have seen but im open to suggestions... So yeh, wat year vette tho?
Old 02-25-2007, 11:26 PM   #10
BadS15v8's Avatar
All vettes, or 93+ F-body Camaro's & Firebirds. Older F-bodys will stick out like a 2WD S-10 Wheel.
Old 02-27-2007, 12:22 AM   #11
Sold da SS and gota Jimmy
97SSindiana's Avatar
Here are my ZQ8's on my 4WD.
[IMG]http://i141.photobucket.com/albums/r43/97jimmyin/IMG_0906.jpg[/IMG]
and here is how much they stick out.
[IMG]http://i141.photobucket.com/albums/r43/97jimmyin/Front1.jpg[/IMG]
They are on a 4 Door Jimmy SLT It is a 97 4WD. Hope this helps.
Old 02-27-2007, 12:08 PM   #12
bowtie99's Avatar
Thanks, your pictures really put it in perspective. I might try something else out, but on the other hand its 4wd and to give it a decent stance, it looks better to have your rim/tire setup to look beefy and maybe stick out a little. Lots of ideas flowing now thanks.
Page generated in 0.59342 seconds with 31 queries
[Output: 78.42 Kb. compressed to 73.20 Kb. by saving 5.22 Kb. (6.65%)]
