Dealer price on Envoy parts
Old 09-07-2007, 12:16 AM   #1
DMP
DMP's Avatar
Do any of you know how much Envoy headlights (pair) and front bumper cover cost from the dealer? And this is the older Envoy....'99 and below, I believe.
Thanks.
Old 09-07-2007, 12:17 AM   #2
forum idiot
orangesonoma's Avatar
Re: Dealer price on Envoy parts
dealer prices are going to be high...
Old 09-07-2007, 12:34 AM   #3
DMP
DMP's Avatar
Yeah I know, but I was just curious. And I was also wondering how much of a discount GM employees get. 10 or 20%? I might be able to get something close and thats why I was wondering about prices. I know it wouldnt make it much cheaper.
Old 09-07-2007, 04:31 PM   #4
Goran's Avatar
your probably better off looking for one in a scrap yard...
Old 09-07-2007, 04:33 PM   #5
Polishing Guru
samandjen1's Avatar
headlights with HID about $1200- 1800
bumper 350
Old 09-07-2007, 04:35 PM   #6
Under Construction
Hawk86's Avatar
$995.00 each i just looked it up.
bumper cover is $358.62
Old 09-07-2007, 11:42 PM   #7
DMP
DMP's Avatar
True, but I doubt many Envoys would be there. Especially those years and if the lights are even there, or in good condition.
The bumper I might actually consider. I know it comes in white......is it called Summit white?
Thanks.
Old 09-08-2007, 12:37 AM   #8
forum idiot
you are nuts.. the only one i ever found was burnt up in the front...
Old 09-08-2007, 04:52 PM   #9
CDN 2WD 2Gen 4-Door!
K Dawg ONE's Avatar
My dealer cost is $300/ea CDN on non-HID envoy headlights...
Old 09-09-2007, 07:37 PM   #10
I order GM parts through this place.
http://www.gmpartsdirect.com/
Old 09-09-2007, 11:33 PM   #11
Polishing Guru
samandjen1's Avatar
thats a sonoma light
Old 09-09-2007, 11:34 PM   #12
Polishing Guru
samandjen1's Avatar
Thanks.
Bumper is black
See in my avatar pic
Old 09-11-2007, 11:47 AM   #13
K Dawg ONE's Avatar
Actually its not. I work at a GM store. Thats my cost on a non-HID assembly each
Old 09-11-2007, 11:53 AM   #14
Polishing Guru
samandjen1's Avatar
its same as a sonoma headlight
Envoy ovals are HID only, it was an upgrade option
Old 09-11-2007, 02:46 PM   #15
K Dawg ONE's Avatar
Your right, but you can buy it as a replacment item without the ballast, igniter, bulb, etc...just as the headlamp assembly...you dont have to buy it complete with the HID (though the dealer will try and sell you the whole thing))...i kept the HID system out of my 98 Voy when I wrote it off...thats how I know, cause I only needed the housing...
Old 09-11-2007, 02:48 PM   #16
K Dawg ONE's Avatar
Your right, but you can buy it as a replacment item without the ballast, igniter, bulb, etc...just as the headlamp assembly...you dont have to buy it complete with the HID (though the dealer will try and sell you the whole thing)...i kept the HID system out of my 98 Voy when I wrote it off...thats how I know, cause I only needed the housing...
edit
Old 09-11-2007, 04:57 PM   #17
Polishing Guru
samandjen1's Avatar
so u replaced the HID headlight with a jimmy/sonoma headlight. and convert the new headlights the halogen and not HID?
Old 09-13-2007, 01:50 PM   #18
K Dawg ONE's Avatar
I havent ordered them yet (priced them out the other day though), but, right now i have 98 Vada headlights on my Jimmy. I have the HID system from my Voy when I wrote it off. I will be ordering the Envoy headlamp assemblies only, without HID (just as if say, you cracked your envoy headlamp...the HID is still fine, but, the housing needs replacment.). So I will be putting my old Voy HID into my new Voy housings and then putting them on.
Potentially, can you buy Envoy replacment headlights without the HID at a lower cost and just run halogen 9006's? Yes, you can...
Old 09-13-2007, 10:29 PM   #19
Polishing Guru
samandjen1's Avatar
halogen low beams dont fit, and HID sheild will block a lot of light.
Old 09-14-2007, 12:35 PM   #20
K Dawg ONE's Avatar
Alot of people I see driving Envoys dont have the HID anymore cause its too expensive to replace once something goes and they ended up retroin halogens to fit. And yeah, the shield will block alot of light.
But, back on original topic, you can buy the headlamp as a replacment part from GM without having to buy the HID...weither you use HID or retro a halogen to fit is up to you..
Old 09-21-2007, 02:27 AM   #21
DMP
DMP's Avatar
Is the Envoy bumper available in any other color than black?
Old 09-21-2007, 01:48 PM   #22
K Dawg ONE's Avatar
Nope.
Old 09-21-2007, 02:23 PM   #23
Broke User.
There's a pair of Envoy lights on eBay right now for $450.
Keystone Auto sells remanufactured Envoy front bumpers for $175. Keystone doesn't have the lights though.
Old 09-21-2007, 09:40 PM   #24
DMP
DMP's Avatar
Nope.
That doesnt make sense. I dont understand why the Envoy bumpers were painted, but if you get a replacement bumper....it only comes in black.
I guess GM wanted to cut down on the cost?
Old 09-21-2007, 10:03 PM   #25
Broke User.
The reason they're only offered in black is most likely because they're gel coated. That's common for most replacement parts.
Old 09-22-2007, 12:40 AM   #26
Polishing Guru
samandjen1's Avatar
no its not gel coated, it polyurathane (sp)
They are black and need to be painted to match
Old 09-22-2007, 02:27 PM   #27
K Dawg ONE's Avatar
^^^He's right. They arent painted black, they are just black plastic.
Old 09-24-2007, 07:34 PM   #28
Broke User.
Ouch. I wonder why they don't base coat them like GM does with most of their replacement parts.
By the way, I've been looking at the whole headlight deal since reading this.
First up is the basic headlight, the second one is the optional upgraded unit, and the third light is an Envoy headlight (a little foggy).
Old 09-25-2007, 10:26 AM   #29
K Dawg ONE's Avatar
^^Sorta.
The first one is a jimmy sonoma headlight w/o fogs.
The second one is the jimmy/sonoma with fogs (i beleive you couldnt get these till 02...i think).
And yes, of course, the 3rd is the envoy lights
Old 09-25-2007, 10:37 AM   #30
CubanSDime's Avatar
so yeah im a gm parts represenitive down here in miami.
get me part numbers and i'll get u prices
Old 09-25-2007, 10:44 AM   #31
CubanSDime's Avatar
lets put it like this... i had the original envoy lamps in my hands
they come without the hids, and they were still kinda steep for me
plus they come seperate from the mounting brackets and u cant use the sonoma ones cuz they're different
so i just got the jimmy ones with the fogs in em and slaped a pair of hids in there.
the fog lamp holes have police strobes in em to take care of the open holes.
i like it. its not an arm and a leg and it looks nice imo
Old 10-05-2007, 02:48 PM   #32
K Dawg ONE's Avatar
Do you have a Keystone part number? I cant seem to find it....
Page generated in 1.12075 seconds with 32 queries
[Output: 148.59 Kb. compressed to 136.09 Kb. by saving 12.50 Kb. (8.41%)]
