dash lights out! 4x4 doesn't work! help!
Old 08-11-2007, 08:33 AM   #1
snakewood's Avatar
i didnt know where to post but i need help bad.
i have a 97 blazer 4door 4.3l. my aftermarket deck went out so i put a new one in. a turned on my truck and the lights on. but my dash lights woulnt turn on. i tried the dimmer knob and no luck. checked the fuses and they were all good. later in the day i tried to put in 4hi and i noticed then that those lights were lit up. tried to put it in 4hi and it didnt work. everything worked fine until i re-did the deck.
anyone have this problem? i need to get it fixed asap andif i can do it myself i would be much more happy. thanks
Old 10-20-2007, 08:57 AM   #2
blazeron22s's Avatar
Re: dash lights out! 4x4 doesn't work! help!
I am having the same exact problem exept mines a 2wd. While replacing my deck i did see some smoke, not sure where it came from. I checked all the fuses none blown?
Old 10-20-2007, 11:11 AM   #3
dunno about the electrical but if your t-case is still shifting then you can use some vise grips on your front diff vacum actuator, its under the battery just squeeze it and put on the visegrips so the cable wont loosen.
Old 10-25-2007, 07:18 PM   #4
pinnacle's Avatar
i had the same problem after the dealership replaced the front diff. in my 95 4x4. first no lights worked. then the 2hi randomly lit up. then the blazer would go into 4 - low but 4hi would not respond. and mech. said that it was the t-case. so long sotry short i just sold it. sorry im no help and just a downer... i miss my blazer
Old 10-25-2007, 07:53 PM   #5
no longer has a 95
95 S_Trucker's Avatar
check your fuses. The 4wd switches and interior lights use the same fuse.
Hope this helps
http://www.s10forum.com/forum/f134/d...w-this-319953/
Edit cause i cant read.
I guess check your wiring
Page generated in 0.56436 seconds with 31 queries
[Output: 54.08 Kb. compressed to 51.36 Kb. by saving 2.72 Kb. (5.03%)]
