eCkO
dash lights FLASHING!!
i have a 2001 chevy blazer 2dr 2wd. it started last week all be driving and out of know where my abs light brake safety belt airbag and i think ses light will start flashing. the radio cuts out for a second 2... what could this be
and its done it a few times already...any help???? |
sawzall's are cool
Re: dash lights FLASHING!!
hope you find out cause i havent yet i got the same problem i checked all the connection and fuses even tried a new cluster with no luck
eCkO
its krazy all jst be drivin and it flashes...the only thing i can think of is the alarm i got or the metel knee saver thing that i took off......??? any help at all anyone???
eCkO
Any Help Please!!!!!!
Mr. Sparkle
Battery Terminals clean?
eCkO
ima check that!!
forum idiot
ignition switch...maybe...
I'm slap happy, bitches!
yeah, ign switch, and if thats not it, you cluster is fvcked.
sawzall's are cool
how can you tell if its the ign switch i have a new one to put in since i bought it used i figured id play it safe just havent put it in yet
forum idiot
the ignition wires will have connection during the entire turn...the acc wires will drop out when you crank the starter... but in newer s-series there are two red wires so you will have to play around with it... |
when i have a hunch on an ign swicth prob, i use a big light back probed into the circuit in question. if it dies, then i found it.
eCkO
well i disconnected the battery and connected it back and it hasnt did it since. but it could be my ignition switch....thanks for the info..
