corvette wheels
I have a '99 4wd s10 Blazer, and i would like to know what oem vette wheels will fit it. Im a newby , hence the name.
Re: corvette wheels
I believe all vette wheels will. I know for a fact that c5's and c6's will bolt right up.
Re: corvette wheels
yes c5 and c6 wheels will fit as well as any of the 93 and up camaro wheels.
Starting from scratch...
Re: corvette wheels
x3
4wd= no spacers required, bolt pattern is the same, 5 lug x 4.75" 2wd= 2.25"-3" spacers depending on particular Gen (C4, 5, or 6) and desired distance from fenderwell. |
Thank you , i now know what i want to get.
Re: corvette wheels
Will these fit , 17 x 9.5 ? There from O.E. wheel.
Re: corvette wheels
Re: corvette wheels
On a 4wd, they will bolt up and sit just like a stock wheel. You may have a little rubbing at lock, but it shouldnt be bad at all. |
Registered (Ab) User
Re: corvette wheels
Click here to see what they look like on a 4wd.
Re: corvette wheels
Im looking to get the black ZR1's or the black cross-laced. Wow ! But yours look great ! It's going on a white Blazer. I think it will offset pretty nicely.
Re: corvette wheels
Re: corvette wheels
a large sidewall tire could be done also. I have seen a couple 4wd's on vette wheels with tall sidewalls. It actually looks pretty good too. Those were all lifted though. I'm not sure how it would look on a stock height truck. You could also just go ahead and drop yours. |
Re: corvette wheels
Yea , im thinking about that too
Re: corvette wheels
how wide can the weels can be? And how much backspace is there on 4wd? Thank you
Japan bound
Re: corvette wheels
here are mine, its a 2wd 4 door, i dont know what the offset for a 4wd is, but my rears are 10.5 inches wide, and i had to use spacers to put mine on, but like they already said, you wont need them on yours. the tire sizes are 245/45/17 in front and 275/40/18 in back. and that is a 3 inch drop all the way around, it looks lower in person than in the picture
Re: corvette wheels
Im wondering about how 17x11's will fit. You guys know if it will ? There's a guy wanting to sell some.
Re: corvette wheels
My 96 2 dr blaze is lowered with 3" blocks, extreme leafs, 4wd rear end. ZR1 wheels 17 x 11, with 315 x 35 tire, no rubbing & fits under the fender lip. Frt had to have I think 2.25 spacers to align everything up.
Re: corvette wheels
That's what i needed to know ! Thank you
Josh in RI
Re: corvette wheels
Just stuff I'm looking to know before I finally get them on and discover a problem... Thanks, Josh |
Re: corvette wheels
Re: corvette wheels
OK, this is what has me confused. Elsewhere someone posted that their 235/75/15s on the front of a 2wd would rub at full lock. My 225s do not. These are only about 8.5" wide, so I'm trying to figure out how a tire that is nearly 3" wider is only rubbing "a little" at full lock???
Perhaps they did something to their truck because it makes no sense that stock 4wd vehicles would have 235s up front and have no problem with clearance but a 2wd would. The other part that sucks is that tires for a 17 or 18 corvette rim that are the same dia as OE seem to be very very limited and cost a ton. |
Re: corvette wheels
I had 235-75X15 for a while on my 2 wd Blazer and there was a slight rub at full lock. The stock 235-70X15 do not rub.
Re: corvette wheels
#24 |
Josh in RI
Re: corvette wheels
- Where can I get them from? - Are they a reputable company? - And lastly, How Much $$$? And with a spacer that wide, how much of a risk IS there at snapping lug bolts from being extended so much? This is the downfall I was advised of when starting to inquire about these at my normal speed shop... Agagin, any and all insight is helpfull right now, as it'll help me along the way with this part of the demon project!!! Thanks again, Josh |
#25 |
Re: corvette wheels
#26 |
Re: corvette wheels
not sure about price or where to get the spacers from or the price tag on them because I have never used them.
The spacers I have seen though bolt up to the stock lugs, then have a seperate set of lugs to bolt the wheels to. I think it would be a good idea to put some stronger lugs in, but I honestly dont know if it would really make a difference. |
