I have a 95 blazer w/sealed beam headlights, I have all the blazer parts for 98 and up front end change except the core support. Today at the junk yard I found a 2000 gmc s15 pu,it has the large composite headlights. Will the chevrolet grille and headlights bolt to the gmc core suppot????????
Negative 10
Re: core support ?
no
Re: core support ?
Sure will!
Negative 10
Re: core support ?
how?
you have to change the core support when you want to change the front end |
Re: core support ?
kennymo- ?
Let me put it a different way, On year model 2000,are gmc and chevrolet core supports the same ? |
Negative 10
Re: core support ?
As far as I know they are different
Re: core support ?
They are exactly the same. Why would they be different? The headlights use the same brackets and everything. Ive done this swap before. If you dont know or are not sure dont post.
Re: core support ?
If you are going from 94-97 to 98-up the core support should be changed. Chevy and GMC supports are exactly the same. Hope this helps.
Re: core support ?
I am changing the core support, I just wanted to know if I could use the gmc support on the chevrolet.
I'll pick it up tomorrow.... Thanks for all the help!!!!!!!!!!!!!! |
Re: core support ?
They are the same.
And to prove it, here's the LMC page that says it: ![]() |
I Need $
Re: core support ?
if you are going to convert to a composite headlight you have to re-do the headlight wiring harness
