coolant overflow tank
Old 06-04-2007, 02:28 PM   #1
chopshop's Avatar
i need to know where i can find a new coolant overflow tank for a '96 Olds Bravada
mine has built up corrosion from the anitfreeze on the inside ive tried to use a long brush to clean it but i cant get all of the corrosion out any suggestions on what would dissolve this stuff or where i could find a clean one?
Old 06-05-2007, 05:11 AM   #2
Pussy Wrangler
AK49BWL's Avatar
Re: coolant overflow tank
I stuck the end of a pressure washer in mine and blasted the junk out of it, worked pretty well you could try that.
If that doesn't work you could check your local auto parts stores like napa, schucks etc.. maybe ebay or a junkyard even.
Old 06-05-2007, 08:14 PM   #3
Hates 'know-it-alls'
summitracing.com
Old 06-09-2007, 12:54 AM   #4
Auto Parts Fast at RockAuto
Old 06-09-2007, 05:30 AM   #5
Crazy for a square body
Kiko's Avatar
Have you tried clr?
Old 06-11-2007, 11:41 AM   #6
chopshop's Avatar
i took it to the car wash and used the pressure washer
.....at the time i had to replace the water pump and it sealed fine but now i think the intake gasket is leaking, any ideas on how long that will take?
what the hell i mean you change one thing and something esle goes wrong with the engine
Old 06-13-2007, 08:22 PM   #7
Slap my meat on your pita
GeorgesBlazah's Avatar
Couple hours to do. It took about a half day to do mine. Of course Ive never done one before.
Page generated in 0.57193 seconds with 31 queries
[Output: 59.75 Kb. compressed to 56.36 Kb. by saving 3.39 Kb. (5.67%)]
