Coolant Leak - Water pump
Old 03-04-2009, 03:55 PM   #1
Goran's Avatar
I'm leaking a lot of coolant underneath the Envoy...
I believe it's coming from the waterpump...
How long does it take to change the water pump?
anyone have the process or links to it?
also anything else that i should change while i'm at it?
Envoy has 230,000km and thermostat was changed last year...
Old 03-04-2009, 04:07 PM   #2
Re: Coolant Leak - Water pump
My s10 actually just started doing the same thing... I started puttin caddy lights in then somethin breaks... everytime... sorry I have no help, I know how but I have to do it cant think to just list steps sorry man.
Old 03-08-2009, 12:27 AM   #3
I can change one in less than 45 minutes. Remove the fan and belt. Remove hoses. Unbolt 5-7 bolts. Reverse removal. It's really easy. The pump comes out without having to remove major brackets or components. Check with www.autozone.com if you need specific instructions.
