Coolant leak fixed but now A/C comp clutch disengages after engine warms up.
Old 09-26-2008, 03:15 AM   #1
I have a 98, 4.3L 2wd chevy blazer. Recently it started leaking coolant from the driver side of the engine. I took it to the repair shop and they fixed the leak, but now the A/C compressor clutch disengages as soon as the engine reaches its normal operating temperture.
Can somebody give me a clue as to what could have gone wrong?
Old 09-26-2008, 08:06 AM   #2
Local Tech
ls1s10onair's Avatar
Re: Coolant leak fixed but now A/C comp clutch disengages after engine warms up.
let me ask you a few questions that will help.....
1- does the a/c work as cold as usual b4 it shuts off?
2- does it go back on at all?
3- the temp. stays at 210 or less?
4- ur temp gauge is working smoothly? Not going up and down all the time?
i have reasons for all these questions.....
Old 09-26-2008, 11:33 AM   #3
Hi, thanks for your help.
1- Yes
2.- No. It works again only after the engine has been turned off for a while and cooled down.
3.- Yes
4.- Gauge works smoothly.
Old 09-28-2008, 12:14 PM   #4
Registered (Ab) User
Yogi's Avatar
Subscribed to learn the final answers.
Old 09-29-2008, 12:05 AM   #5
C130 Maintenance in Japan
nate98blazer's Avatar
your freon is low, go to any parts store and they will have the guages that you can put on there along with a can to fill your freon
