converting spindles
Has any one ever switched the spindle assembly from a jimmy/blazer to an s10 type spindle? If so what is envolved? I picked up a set of 2in drop spindles from a s10 localy for cheap what would be involved in swapping them out on my jimmy? thanks for any help in advance!
bellcranks no more
Re: converting spindles
you lose braking power. i wouldnt do it
I'm a huge ass
Search. Many people have done this for the fact that the blazer has more pistons per caliper.
bellcranks no more
he's thinking of the opposite.. placeing s10 spindles ONTO a blazer |
I'm a huge ass
For some reason Blazers and S10s both use different spindles... but it'll cost more then it's worth. It would be cheaper to just get the blazer drop spindles then to take all the work to just single piston calipers on your heavier blazer.
The Dreamsicle
only the 98+ blazers have the differnt spindles. |
do they make a fwd drop spindles for an s10 blazer 95-97
bellcranks no more
the only fwd s-series that i know of is the electric s10s..... and normally you dont call them spindles when they have a halfshaft |
I'm a huge ass
![]() There is no such thing as a FWD s10. Every s10 out there has been built on the same chassis. You can use the same spindle on any year dime and it'll work, blazers are a bit different after 98. |
sorry i meant 4wd drop im still gonna say spindle to which the half shaft goes thru and bearing mounts on to via three bolts i know they make them for larger gm vehicles i just wanna know if they make them for a blazer
never mind just found a better trick gotta love google
STUNTiN ON THEM GRANNiES.
fyi its not a spindle because its on a torsion bar suspension.. when you look up spindles you usually find there for 2wd...
thats what kept coming up when i searched im goin to get belltech keys and go that route just doing a 3/3 drop wanted lower but still need 4wd for the weather here
