Cleared Headlights for GMC Jimmy
Old 04-21-2004, 10:39 AM   #1
Majikull's Avatar
Exclamation Cleared Headlights for GMC Jimmy
Does anyone know where i can find the steps to clear out my headlight assembly on my 98 GMC Jimmy? i've heard of a lot of things, like using a hairdryer and baking the assembly in the oven to losen the glue, but i'd really like to know what works the best. and if there are any sites out there with step by step procedures.
Old 04-21-2004, 12:11 PM   #2
It's all rattle canned
dagreenmonster's Avatar
Re: Cleared Headlights for GMC Jimmy
theres a few different ways to do it...i melted the hell out of the casing with the hairdryer, and then i pryed open the casing just enough to get the amber piece out....then i sealed it back up with gm black silicone and it is good as new....if u look at the headlight from behind, which ur never gonna see, u can see some melted spots, but ur never gonna see it so it dont matter
Old 04-21-2004, 10:18 PM   #3
Derrick824's Avatar
I set my GMC lights on a piece of cardboard on a cookie sheet inside the oven and heated for a few minutes on 200*, then used a flat-head screwdriver to pry the headlight apart. After you get it apart the amber piece comes right out. Make sure to use silicone to seal it back up good. Also make sure not to get fingerprints or anything else on the inside of the headlight.
Old 04-24-2004, 06:00 PM   #4
V8 Member
the_dubster98's Avatar
just did mine today.. its easy.. set the oven at 200 and leave them in there for about 20 minutes then i slid the amber pieces out.. and while the glue was still tackie i put it back together.. should leak.. but we will see... looks awesome.. 3157 amber bulb is what youll need if you dont wanna get in trouble with the cops.. looks awesome if you ask me
Old 04-24-2004, 06:45 PM   #5
Majikull's Avatar
do you have to peel the black rubber off before you stick it in the oven?
Old 04-25-2004, 12:21 AM   #6
V8 Member
nope sure dont have too.. but makes it easier if you do.. be careful not to stretch it either.. my passanger is stretched a little .. sucks for when you go to clue it back on..
Old 04-25-2004, 12:39 AM   #7
Drivin' 2 Noma's
ZQ8 NOMA's Avatar
I put mine in the oven on a clean cookie tray lense down. I removed the rubber piece and had the oven at just under 200 with the door open a bit. I checked them every two and a half minutes and worked at them a bit with a flat head screw driver. I took 4 times checking and heating per light for the glue to to finally give. I tryed with a heat gun at first but the oven is dfinately the way to go. I also used clear silicone to seal them back up.
Old 04-26-2004, 09:31 PM   #8
i just did mine today...does anyone else have the built in fog lights? mine i heated up in oven at 200 for about 5 minutes took out and tried prying...got it to move , put back in for another 4 and then pryed them right apart, pieces fell out and stuck it back together. then i siliconed the edges back up and superglued the rubber piece back on them. I however got a suprise when i did the right side and as i was superglueing it i noticed there is a crack in the housing that goes all the way through in the bottom left corner where there is no light. Its small but noticeable up close, i have no idea why it is cracked , def bummer. Has anyone put strobes in the corner where there is no light? I am thinking of doing just that , i think itd' be pretty hot lookin.. I will post pics when i get it all dried and put back in, I also went to the wallyworldmart and got the amber 3157 bulbs , so far it looks pretty awesome. Im hopin however it wont affect the fog lights at all.?
Old 04-26-2004, 10:07 PM   #9
V8 Member
yeah mine did the same exact thing actually with the cracking... molding flaw maybe??
Old 04-26-2004, 10:15 PM   #10
has committed suicide!
Got-20z's Avatar
mine has the built in fogs too
Old 04-26-2004, 10:19 PM   #11
Primer Spots
mrshaft696's Avatar
i found a heat gun easier, and the stuff just pealed off, the hard part is seperating the backing from the lens, you have to be super careful not to crack the reflective backing or it could get messed up...some of the plastic will proably crack but just fill it up with silicon, clear or black..dosent matter no one is gonna see it
Old 04-28-2004, 10:15 PM   #12
maybe i don't know...looking at that way it does seem possible, there is no crack in the lens or marks or anything and it just looks like it is like that but is definitely broke....wierd...anyone else have this problem?
Old 05-04-2004, 01:21 PM   #13
Landmine Carburetor
sausagefingers76's Avatar
I just used a hairdryer. just did a corner at a time and pulled it apart w/ a screwdriver. Only pulled up the corners and slid out the reflector, i have the lights w/ fogs so you have to do the both sides. Really easy except one of my lights is a "new aftermarket" and it isn't held with glue, but with some sorta sticky strip that got all over me when i heated it up...
Old 05-04-2004, 02:39 PM   #14
strip rat
Jimmy-James's Avatar
I've got a 95 jimmy with composite lights that i am about to clear out. I'm just amazed at pictures i've seen of em done and how awesome they look!
Old 05-26-2004, 11:54 AM   #15
V8 Member
yeah i got complimented on how the jimmy looked the other day.. i think people notice the jimmy more often now.. now if i can find a tail light that i like and is legal.. but alteza*s are freaking ugly if you ask me.. maybe a caddy sts or what ever them small caddies are called tail light ??
Old 10-29-2005, 01:32 PM   #16
Is there anyone out there that would be interested in clearing me out a set of 1996 Jimmy headlights? I will pay you for your work of course, the headlights, and the shipping to get them to me.. I am afraid to screw it up due to one of my hands not functioning properly since I got hurt at work. If interested, feel free to email me at dvs_one@sympatico.ca and we can try to work something out. Your kindness for helping will be greatly appreciated.
Old 11-20-2005, 07:57 PM   #17
does anyone know where i can see pics of this being done
Old 11-21-2005, 10:03 PM   #18
bagged85's Avatar
have you done it yet? how does it come out just slides out after both sides are seperated?
and what would be the best sealer for these lights? could windshield glue even work or to messy?
Old 12-20-2005, 08:48 PM   #19
Vsandme's Avatar
im going to try this tonight :-) i have an extra set to practice on lol...so i dont mess it up... just look at my sig...yellow...gross :-P
Old 12-29-2005, 05:53 PM   #20
Vsandme's Avatar
i finnally pulled it off, pics in the member rides section, i used a heat gun, worked great :-D
Old 07-04-2006, 01:57 PM   #21
I'm trying to do this as well. Do I remove those four little clips around the outside of the light?
Old 07-04-2006, 02:21 PM   #22
I pee standing
juddspaintballs's Avatar
yeah...I was gonna put in composites in my 96 then clear them out but I didn't want to ruin two expensive new headlights by screwing it up and cracking them. so what did I do? I spent more money and did a 98+ blazer conversion and bought clear lights for it
Old 07-04-2006, 02:32 PM   #23
I've baked this thing for like 15 minutes at 200 and it still wont move. At what end did you guys pry the casing off?
Old 07-06-2006, 06:17 PM   #24
V8 Member
the glue should have been soft by then, but i had to use a flathead screwdriver to give it a little pry, be careful thou not to pry on the reflective side too much cause it will crack, i cracked mine, but i cant even tel where unless you look at it very close..
Old 07-06-2006, 06:48 PM   #25
I guess I'll give it another try and leave it in for 15 minutes uninterupted
Old 07-06-2006, 10:45 PM   #26
yea, I've got mine in the oven, as I type this I tried the "check every few minutes" but that's not really working for me. I'm gonna give em 10-15 and see, then.
Old 07-07-2006, 12:11 AM   #27
they're out of the oven, silicon-sealed, and back on my truck
Before:
After:
Old 07-07-2006, 12:16 AM   #28
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
Before:
After:
That is what mine look like,
I will have to try this soon.
Old 11-13-2007, 10:19 PM   #29
Biggs's Avatar
what about the blinker? or the hazards? do they still flash orange? anyone get pulled over?
Old 11-13-2007, 11:58 PM   #30
Before:
After:
do you have a pic of the whole truck?
Old 11-14-2007, 12:18 AM   #31
Megabyte
travy's Avatar
I think it looks bad with 95-97 composites, unless you have a clear ruffled reflector to put inplace of the amber colored one.
I suggest when you do the oven trick that you leave the door open on it.
Old 11-14-2007, 01:24 AM   #32
99 GMC Jimmy SLS
Don't have an oven, can try it on the microwave? I think it will be faster, maybe even better
nahh.... just kiddin', I'll try this soon, looks really nice and clean.... 2 thumbs up for that
Old 11-14-2007, 07:59 PM   #33
Pimp in training! I wish!
pimp99noma's Avatar
When I did mine I used a screw driver and just slowly worked my way around it. It was so easy I would not even try to use an oven. The glue is real brittle and crack if you take your time and it still took less then 10 min start to finish per light.
Old 11-15-2007, 02:27 AM   #34
minitrkingking's Avatar
My headlight on the noma is "fogged" or kinda blemished. If I remove the backing and clean it do you guys think it'd work? I planned on clearing them anyway but I may have to buy a new one.
Old 11-16-2007, 04:57 PM   #35
860gmc's Avatar
does any one have a pic of one of those years..?
cuz i have a 96 and is it the same process.?
Old 01-15-2008, 11:47 PM   #36
STPSYDR
BLACKZQ8stepside's Avatar
B*U*M*P
I also have a set of 96 bravada/jimmy headlights that I want to clear out, but I want to see how it looks first
Old 01-16-2008, 01:55 AM   #37
Megabyte
travy's Avatar
It looks awful, unless you can find a clear refecter that has the ripples in it.
Old 02-23-2008, 01:12 PM   #38
immexicansostfu's Avatar
LOL yea but it sure does look a whole lot better than having that shit looking amber reflector in it....would anyone happen to know where u can find these clear reflectors for a 95 jimmy?
Old 02-23-2008, 10:09 PM   #39
Megabyte
travy's Avatar
Only if you can find a clear ripple reflector. Other wise, without it, it's horrible.
Page generated in 0.65503 seconds with 31 queries
[Output: 170.95 Kb. compressed to 156.22 Kb. by saving 14.74 Kb. (8.62%)]
