brakes knocking....
Old 08-02-2008, 11:22 PM   #1
brakes knocking....
I own an 04 blazer 2WD and recently changed the brake pads on the blazer. Rotors were fine on the front, so I replaced the rotors on the back. Now, I'm hearing this constant knock noise when I'm hitting my brakes, and this knock is only coming from the front driver's side. I know it has something to do with my brakes, considering it never did this before. Any advice would be appreciated. Anybody else experience this situation?
Old 08-03-2008, 03:47 PM   #2
Re: brakes knocking....
nobody ever had this issue?
Old 08-03-2008, 07:04 PM   #3
Most often a noise like that happens when the pad is allowed to move/rattle while in the caliper. Make sure the hold downs are there and in place. Also, I don't know about 04 pads, but the S-10 standard for many years had tabs on the pad that had to be smacked with a hammer and bent into the caliper to keep from moving. Just something to look for. (and make sure you tightened the bolts all up.)
Old 08-03-2008, 11:54 PM   #4
i believe that the caliper bolts that are also the slides have a rubber bushing inside the bracket that may be worn.
Old 08-04-2008, 01:26 PM   #5
bellcranks no more
greencactus3's Avatar
how did you decide your front rotors were good?
maybe they need to get turned?
Page generated in 0.55891 seconds with 31 queries
[Output: 52.22 Kb. compressed to 49.57 Kb. by saving 2.65 Kb. (5.07%)]
