brake question
Old 04-07-2008, 09:27 AM   #1
Goran's Avatar
brake question
my inside brake keeps wearing out, (under 3000km) any ideas?
Old 04-07-2008, 09:34 AM   #2
Local Tech
ls1s10onair's Avatar
Re: brake question
chances are, the slide pins are frozen.... if you are 4wd, the bolts go thru a slide pin in a rubber boot.... they have to slide freely, so when the caliper pushes on one side, it equals the pressure to both pads..... thats the most likely problem..... also, you can check the caliper by using a digital thermometer (gun style).... Theyre like 10 bucks if you dont have
drive around stopping hard for 10 min or so, and check the temp on the rotors thru the wheel..... a stuck caliper will be the hot side...
to do it right, id change the pads, calipers, and brake hoses on both sides, but i hope i helped ya out
Old 04-08-2008, 05:39 PM   #3
Goran's Avatar
Re: brake question
it's on the rear, "stealer"ship is suggesting it's a locked parking brake...
they said the caliper tests out fine...
Old 04-10-2008, 09:18 PM   #4
goin broke but n style
S15vortecpwr's Avatar
Re: brake question
is your parking brake intregrated in the caliper or is it shoes inside the rotor?
But I agree with LT1S10onAir
Old 04-10-2008, 09:38 PM   #5
Re: brake question
they are usually inside the rotor. alot of times the little hold clips break and then the shoe rubs its self away inside the rotor/drum deally.
Old 04-18-2008, 12:26 PM   #6
Goran's Avatar
Re: brake question
The shoe is inside the rotor....
Old 04-19-2008, 09:01 AM   #7
Re: brake question
the parking brake one is im not sure how it would lock on but
Page generated in 0.57766 seconds with 31 queries
[Output: 59.17 Kb. compressed to 55.75 Kb. by saving 3.42 Kb. (5.78%)]
