BRAKE light
Old 08-18-2008, 02:20 AM   #1
mini' less.... :(
project2001's Avatar
BRAKE light
well i busted a front brake line on my jimmy, after fixing it and bleeding the brakes, after driving about half a block the BRAKE light comes on, the brakes are still a little spongy(still needs bled a little more), but it stops great, but if you sit there and put alot of pressure on the brake pedal it will slowly fall to the floor.
i noticed there is a bleeder valve on the ABS block, does it need bled up there also?
Old 08-19-2008, 06:40 PM   #2
Registered (Ab) User
Yogi's Avatar
Re: BRAKE light
Yes, the ABS needs to be bled, but it sounds like you've got a bad master cylinder.
Old 08-19-2008, 07:42 PM   #3
mini' less.... :(
Re: BRAKE light
everything worked perfectly fine until i put the new brake line on, it doesnt seem to be loosing any brake fluid either
Page generated in 0.55635 seconds with 31 queries
[Output: 46.36 Kb. compressed to 44.37 Kb. by saving 1.99 Kb. (4.29%)]
