Bolting flywheel to torque converter
I searched for an answer to this but couldn't in a reasonable amount of time, so here is my question. I am trying to bolt the flywheel to the converter and the two are about a quarter inch away from each other. I am asking if the two will draw together when tightening the bolts or am I walking into a disaster later? The bolts seem to be turning in very easy. But when I tried to push the converter into the flywheel, it seemed to hit something. The torque converter turns very easy. I was assuming the center of the crankshaft was mating with the torque converter. But with the help of the bolts, it will fully seat. I am in no hurry that is why I am asking here before I do it. I am pretty darn sure what I am doing is right, I just want to be 100% sure from somebody who has already done it.
Thanks in advance, Eric |
Local Tech
Re: Bolting flywheel to torque converter
is the trans fully mated to the engine? like flat against one another? if so, then do what u will...... if not, id def get the motor and trans mated first..... the torque converter locks in place TWO TIMES in the trans.... if the engine/trans arent close enough, bolting up the converter will eventually ruin the converter, and maybe the valvebody
Yes, its fully mated and torqued down. Nothing is binding between the flywheel and the converter. Converter turns freely when I turn it clockwise. Thanks for the quick reply.
I'm slap happy, bitches!
if you have the trans and engine bolted together tight, and you can spin the torque, an 1/8 to 1/4 is about the right distance if you have the torque pushed all the way into the pump, you can use a prybar and pry it onto the flexplate now, and bolt it with the 3 bolts, just remember to use the double d hole in the flexplat to line it all up, put that bolt in, and tighten it, roll the motor 120 degrees, and continue, you'll be fine.
What is the double d hole in the flexplate? Thanks.
its the one thats not a perfect circle.
Gotcha! Thanks for the help. I appreciate it. Eric
