eCkO
bogging
yes i got a 01 chevy blazer 2dr 2wd and it started bogging when i drove up to LA from fresno.....about 290 300 miles and it started bogging i think its the cat converter....what are the signs of the cat going out..PLEASE HELP.....
Re: bogging
The catalytic converter in my 98 4x4 4 door went out a few months ago. It was rattling like crazy, but there wasn't any really noticeable decrease in performance, aside from a mpg or two.
eCkO
Re: bogging
n e 1 else..
ZR2 member
Re: bogging
Fuel filter or pump.
eCkO
Re: bogging
thanks thats what i think it is...how would i knoe if its the fuel filter when i take it out..or just replace it.. |
ZR2 member
Re: bogging
How many miles on it?Ever put one on it before?Best just replace it.
eCkO
Re: bogging
117000 i got it with 9800 for good price...umm should i change the pump or the filter.. like sometime when im at a light it will bogg down to like 500 rpms or a lil lower...i really need to change it but am busy.... i work 6 days a week
Slap my meat on your pita
Re: bogging
Mine idles at about 500-600 when its warmed up.
ZR2 member
Re: bogging
Re: bogging
eCkO
Re: bogging
just changed the fuel filter........
![]() ![]() it wasnt that...it like does it when its idle and then when i step on it hard.......but no SES light could it be my air filter..i got a cheap 1 i bout from autozone it a red POWER ADDER..lol i got it for 20 cuts..my stock got mestup when i got an a accident... could it be that its like its chockin or sumthin... |
eCkO
Re: bogging
minitrucker in training
Re: bogging
i had a very similar problem, mine always wanted to stall out when i was at lights or stopped. the problem was the EGR valve had carbon built up in it. i replaced the EGR valve and it ran awesome after. maybe thats your problem?
eCkO
Re: bogging
was the SES light on cuz mine isnt |
Banned
Re: bogging
i would say fuel pump also
eCkO
Re: bogging
i just changed the filter and it was dirty as hell the gas was almost black..is the fuel pump a bitch to fix and is it expensive
Re: bogging
Did yours bogg down while driving say on the interstate? That's what mine was doing I thought it was spark so I checked my plugs and they where in really bad shape so I replaced the and the cap rotor and wires. Went to start it back up and nothing, Checked all the work I'd done nothing, Check fuel pressure and got none and I could not here the pump running, so if you have a guage check for fuel pressure at least check to see if you can hear the pump running. The pump cost $218 at advance auto. You can't get just the pump you have to buy the whole assy. My 4 door was actually easy to get to but I think the 2 door version is a little harder to get to I no my wife's 95 was a pain.
eCkO
Re: bogging
and are u talkin about that hissing noise when the truck is running? and yes i was on the interstate and like it struggles i used to go 70 at 2000RPMS now its like 65 at 2000RPMS or maybe im trippin..1 more q i dont wanna sound stupid but how do u check the fuel pressure? thanks |
eCkO
Re: bogging
there is some BLACK dirt or stuff thats cumin out of my catback...like i took off the muffler and there is like a plugg or sencr right there well any way i stuck my fingers in there and they got a bunch of black stuff on it could it be my cat..also i got 2 cats should i have 2..i live in california soo we got SMOG..im confused
Re: bogging
plugged cat def i just ran the shit out of mine and it blew out
eCkO
Re: bogging
okay got sumthin...last night i was smashin to a lil town not to far from where i live i was going about 95..and its sounded like it was chokin really bad and the ses started 2 blink so i pulled over and killed the engine..started up fine after ten seconds then like an 1and a half later i was at a light it turned green started drivin and it sounded chokin agian really bad same thing ses started blinkin pulled over and started it back up and it was fine again WHAT Is WRONG is it my cat throwin weird ses codes
Re: bogging
SES only flashes for a misfire, get the codes scanned, might help diagnose it.
eCkO
Re: bogging
all fixed i should have did wat i said i was goin to do TUNE UP the wires and sparks were still from the factory all better runs CHERRY..
