Blend Door Actuator - S-10 Forum
post #1 of 11 Old 11-13-2009, 05:41 PM Thread Starter
User is: stickemdano is offline
Blend Door Actuator
1996 Blazer 4.3. 215,000 kms.
Replaced the DREADED blend door actuator. This job is not fun but also not impossible. Basically just had to keep pulling stuff off until I could get to it. It will take an afternoon and a bit more to complete. Had to walk away a few times and count to ten!!
I had the same 'no heat issue'. I started with repacing the thermostat. No change. Then replaced all the vacuum hoses. No change. I knew it was not the heater core, so I left that alone. Next I tried replacing the temperature control switch. No change. Then I went after the blend door actuator. A lot of people shy away from this but go ahead and do it if you have some basic knowledge and some basic tools.
I broke my hazard switch during the operation and replaced it no problem (easy fix). Now that everything is said and done, only problem I have is that the turn signals (and hazard) do not work. I checked the fuses and they are OK. Any ideas? Is there an electrical connection under the dash I may have forgot about?
post #2 of 11 Old 11-13-2009, 06:03 PM
no longer has a 95
95 S_Trucker's Avatar
User is: 95 S_Trucker is offline
Send a message via AIM to 95 S_Trucker
Re: Blend Door Actuator
double check and make sure the hazard switch is in the whole way. i bet you dont have any brakelights either
99 Blazer 2 Door, 4wd, NV3500, 8.5
99 K2500 LS CCSB 7.4, 4L80E
post #3 of 11 Old 11-13-2009, 11:10 PM Thread Starter
Thanks 95 S Trucker. I just tried pushing the hazard switch in further, but it is in all the way. Also you are right, I have no brake lights.
post #4 of 11 Old 11-18-2009, 08:57 PM
Move over here I come
89S10WBlazer's Avatar
User is: 89S10WBlazer is offline
hazard switch is malfunctioning. had the same problem on my buddy's 96. wiggle it around it should work. if not replace it again.
83 S-10 Blazer 2.8 5 Speed-SOLD
83 S-15 2.8 Standard Cab-Gypsy AT-SOLD
91 S-10 4.3 5 Speed Ext. Cab. 3/3 drop-SOLD
89 S-10 Blazer 5.7 3/3 Drop-DEAD for now
1999 Blazer 4x4 4.3 Kenwood Headunit Hifonics System
2009 Toyota Corolla S 5 Speed
post #5 of 11 Old 12-02-2009, 12:19 AM Thread Starter
Thanks guys. Replaced with another new hazard switch which now works fine. First one must have been defective. Apparently not the first one!!
post #6 of 11 Old 12-02-2009, 05:17 PM
1998 S10 Blazer
2001cvpi's Avatar
User is: 2001cvpi is offline
You should not continue with the same thread NAME and diagnose with a different problem... Blend door? Hazard switch? Sorry, was looking for more on the blend door...
2001cvpi is offline
post #7 of 11 Old 12-02-2009, 05:19 PM
1998 S10 Blazer
2001cvpi's Avatar
Disregard previous thread from me... I see the reost. Thanks
2001cvpi is offline
post #8 of 11 Old 12-04-2009, 09:25 PM
Slap my meat on your pita
GeorgesBlazah's Avatar
User is: GeorgesBlazah is offline
I had to do my blend door on mine...pain in the ass
George
98 Blazah 6in SL - 2in BL - 4.56s - Detroit ITS AN ANIMAL 4x4 BUMPER. IT IS NOT MADE ANYMORE, BUT YOU CAN BUY MINE FOR $6000
BLAZER PICS AND INFO CLICK ME
Founder/Godfather of the Anti-Bag Coalition
"Bags are for groceries"
post #9 of 11 Old 12-10-2009, 12:14 AM
Registered Minitrucker
LeRoy_921's Avatar
User is: LeRoy_921 is offline
****... i gotta replace mine too I think.
post #10 of 11 Old 12-27-2009, 01:12 AM
Gregs93S-10's Avatar
User is: Gregs93S-10 is offline
Send a message via Yahoo to Gregs93S-10
I just relaced the TEMP DOOR ACTUATOR on my 02 Xtreme, but still no luck. My problem is that the temperature door is stuck on high heat.
When I took off the old actautor, I turned the "keyed" lever for the door and I turned it with no problems. The door itself did not seemed jammed....so I replaced the actuator motor itself BUT did NOT solve the problem...
What gives?
The control module is fine...I think. When I switched the temp from cold to hot and visa versa...I could feel the motor turning ever so slightly...a VERY small amount of turning, but, it is getting power....
I know I'm missing something....someone please shed some light on this...thx.
One BadAss '01 XTreme 4.3L; 5-speed !!
post #11 of 11 Old 12-29-2009, 06:29 PM
1998 S10 Blazer
2001cvpi's Avatar
I'm second guessing the control module. Check vac lines?
2001cvpi is offline
