Blazer with 2.2l engine
Old 03-22-2009, 08:55 PM   #1
Is there such a thing as a Blazer with a 4 cyl engine? What kind of tranny would it have?
Just checking?
Thanks guys...Pete
Old 03-22-2009, 09:01 PM   #2
Giggity Giggity
Woody22's Avatar
Re: Blazer with 2.2l engine
No such thing ever.
Old 03-23-2009, 01:48 AM   #3
ZQ8 Blazer
ZQ8 Blazer's Avatar
nope
Old 03-23-2009, 01:53 AM   #4
UN-BANNED B!TCHES!!!!!
NotaDime's Avatar
negative.
older ones had a 2.8, but thats a v-6
Old 03-23-2009, 03:06 AM   #5
Giggity Giggity
Woody22's Avatar
how many time are people gona respond to this thread saying NO.
Old 03-23-2009, 03:09 AM   #6
Fvck New Jersey
Tim99Zr2's Avatar
nope.. they dont exist
Old 03-23-2009, 03:12 AM   #7
NotaDime's Avatar
dont get your panties all in abunch just because you were the first to tell him "no"
this is how whore threads start..... with dumb questions.
Old 03-23-2009, 03:14 AM   #8
Fvck New Jersey
Tim99Zr2's Avatar
why do door pins go bad? i really hate them...
Old 03-23-2009, 03:17 AM   #9
NotaDime's Avatar
*friction + weight.
funny thing you mention that, i just replaced mine TWO days ago in my blazer.
* Friction
From Wikipedia, the free encyclopedia
Jump to: navigation, search
For other uses, see Friction (disambiguation).
Force diagram for block on ground.
Arrows are vectors indicating directions and magnitudes of forces.
W is the force of weight, N is the normal force, F is an applied force of unidentified type, and Ff is the force of kinetic friction which is equal to the coefficient of kinetic friction times the normal force.
Since the magnitude of the applied force is greater than the magnitude of the force of kinetic friction opposing it, the block is moving to the left.
Friction is the force resisting the relative lateral (tangential) motion of solid surfaces, fluid layers, or material elements in contact. It is usually subdivided into several varieties:
  • Dry friction resists relative lateral motion of two solid surfaces in contact. Dry friction is also subdivided into static friction between non-moving surfaces, and kinetic friction (sometimes called sliding friction or dynamic friction) between moving surfaces.
  • Lubricated friction[1] or fluid friction[2][3] resists relative lateral motion of two solid surfaces separated by a layer of gas or liquid.
  • Fluid friction is also used to describe the friction between layers within a fluid that are moving relative to each other.[4][5]
  • Skin friction is a component of drag, the force resisting the motion of a solid body through a fluid.
  • Internal friction is the force resisting motion between the elements making up a solid material while it undergoes deformation.[5]
Friction is not a fundamental force, as it is derived from electromagnetic force between charged particles, including electrons, protons, atoms, and molecules, and so cannot be calculated from first principles, but instead must be found empirically.
When contacting surfaces move relative to each other, the friction between the two surfaces converts kinetic energy into thermal energy, or heat.
Contrary to earlier explanations, kinetic friction is now understood not to be caused by surface roughness but by chemical bonding between the surfaces.
[6] Surface roughness and contact area, however, do affect kinetic friction for micro- and nano-scale objects where surface area forces dominate inertial forces.
[7]
Friction is distinct from traction.
Surface area does not affect friction significantly because as contact area increases, force per unit area decreases.
In traction, however, surface area is important.
Old 03-23-2009, 03:17 AM   #10
Founding member of DA
pack of q tips's Avatar
first gens had a 2.5 4 banger and i think a diesel option for a year or 2
Old 03-23-2009, 03:18 AM   #11
my door pins are original i spray them with zep grease every oil change
Old 03-23-2009, 03:20 AM   #12
NotaDime's Avatar
in the 96??~!
Old 03-23-2009, 03:21 AM   #13
NotaDime's Avatar
lol, see what'd i tell ya!
Old 03-23-2009, 03:22 AM   #14
oh god no the person who had the 96 before me let them get so bad i need new hinges
the 02 is original pins i got it with 36k on it
Old 03-23-2009, 03:24 AM   #15
NotaDime's Avatar
oh, ok i was gunna say.
on my 96 truck i replaced both.
on my 96 blazer only the drivers front door pins have been replaced so far, i need to do the pass side front now.
Old 03-23-2009, 04:07 AM   #16
Giggity Giggity
Woody22's Avatar
lol i was just messin around.... like i always do lol
Old 03-23-2009, 10:21 AM   #17
I'm pretty sure you could special order the 2.2 in the blazer. The 4L60E would be the automatic that came with it, and the 5 speed would be what ever comes on the s10 2.2.
Old 03-23-2009, 12:47 PM   #18
not a 2nd gen one
Old 03-23-2009, 01:15 PM   #19
NotaDime's Avatar
i know, me to..... (i was starting the whore thread)
Old 03-23-2009, 09:12 PM   #20
Thanks a million for the answer! So it did come with a 4 cyl. The guys that gave me that answer won me some $$$$$$$$$$$$$$$$$$ ha ha ha ha.....
My stupid ass brother owes me $$$$$$$$$$$ now!!!!!!!
I hope you don't mind if I copy the answers to show him?
It don't matter what Gen.....just Blazer. Good enuff.
Thanks again to you all. I knew you guys would know.
Pete
Old 03-23-2009, 09:18 PM   #21
ZQ8 Blazer
ZQ8 Blazer's Avatar
Just take them out, naw it's from people leaning on the doors plus the doors weight from what I've heard. Try replacing the door roller pin, that's a bitch.
I have never heard/seen that and don't think that you would be able to special order that, if that's the case the you would have been able to special order a 99-06 fullsize with an 8.1L w/ a T56.
So no.
Old 03-23-2009, 10:03 PM   #22
the door pins aint to bad to replace... its getting that stupid spring back in that is a pain... both my driver and passenger side dont have them in cause the pins went bad twice in less then a year... the second time i didnt even bother and its been like that for 7 months now... if i need to keep the door for an extended amount of time i just move the pin so it hold the door open..
Old 03-23-2009, 10:09 PM   #23
Calico 1st Gen
90blueS10's Avatar
i swear some of the xtreme blazers came with a 4 cyl?
Old 03-23-2009, 10:19 PM   #24
ZQ8 Blazer
ZQ8 Blazer's Avatar
Are you talking to me? Are we talking about the same thing? The thing I'm talking about is pressed into the hinges and the little bracket the spring pushes up against is part of the roller pin, you pretty much have to take the door off to get to it.
Nope
Old 03-23-2009, 10:24 PM   #25
CDN 2WD 2Gen 4-Door!
K Dawg ONE's Avatar
Second gen only came with the 4.3, but, yes, the first gen could come with an I-4.
From wiki:
First generation engines
  • 1983-1985 - 1.9 L Isuzu I4, 2-bbl, 84 hp (63 kW)/101 lb·ft (137 N·m) (California)
  • 1983-1984 - 2.0 L OHV I4, 2-bbl, 83 hp (62 kW)/108 lb·ft (146 N·m)
  • 1983-1985 - 2.2 L Isuzu diesel I4, 58 hp (43 kW)/93 lb·ft (126 N·m)
  • 1983-1985 - 2.8 L (173 cu in) LR2 V6, 2-bbl, 110 hp (82 kW)/148 lb·ft (201 N·m) (VIN B)
  • 1985-1989 - 2.5 L (151 cu in) Iron Duke I4, TBI, 92 hp (69 kW)/132 lb·ft (179 N·m) (VIN E)
  • 1986-1993 - 2.8 L (173 cu in) LL2 V6, TBI, 125 hp (93 kW)/150 lb·ft (203 N·m) (VIN R)
  • 1988-1992 - 4.3 L (262 cu in) LB4 V6, TBI, 160 hp (119 kW)/230 lb·ft (312 N·m) (VIN Z)
  • 1990-1993 - 2.5 L (151 cu in) Iron Duke I4, TBI, 105 hp (78 kW)/135 lb·ft (183 N·m) (VIN A)
  • 1992-1994 - 4.3 L (262 cu in) Vortec 4300 L35 V6, CPFI, 200 hp (149 kW)/260 lb·ft (353 N·m) (VIN W)
  • 1993-1994 - 4.3 L (262 cu in) LB4 V6, TBI, 165 hp (123 kW)/235 lb·ft (319 N·m) (VIN Z)
And...
First generation, also called GMC S-15 Jimmy GMC Jimmy
Production 1983–1994
Assembly Linden, New Jersey, Shreveport, Louisiana, Pontiac, Michigan, Moraine, Ohio, São Paulo, Brazil
Platform GM GMT330
platform Engine(s):
1.9 L Isuzu I4
2.0 L OHV I4
2.2 L Diesel I4
2.2 L (134 cu in) L43 I4
4.3 L (262 cu in) 4300
V6 Transmission(s)700R4/4L60 (1983-1992); 4L60E (1993-1994)
Length 2-Door: 170.3 in (4326 mm); 4-Door: 176.8 in (4491 mm)
Width 65.4 in (1661 mm)
Height 2WD: 64.1 in (1628 mm), 4WD: 64.3 in (1633 mm)
Related:
Chevrolet S-10
GMC Sonoma
GMC Typhoon
Oldsmobile Bravada
Old 03-23-2009, 11:25 PM   #26
ZQ8 Blazer
ZQ8 Blazer's Avatar
Wikipedia isn't a reliable source.
See, I bet you guys didn't know they made this model Blazer:
  • 1992-1993 - 13.2 L (600 cu in) Dodge Viper V-10, Urine Injection, 5,000,000 hp (432 kW)/2,000,000 lb-ft(902 N-m) (VIN P)
http://en.wikipedia.org/wiki/Chevrol...ration_engines
Old 03-23-2009, 11:28 PM   #27
The Dreamsicle
cpolaris502's Avatar
Some first gen Blazers did come with a 2.5l engine. Fact.
Old 03-23-2009, 11:36 PM   #28
ZQ8 Blazer
ZQ8 Blazer's Avatar
They also came with Dodge Viper engines.
Why would someone want a 4cyl Blazer? Resale on that has to be crap.
Old 03-24-2009, 03:12 AM   #29
Giggity Giggity
Woody22's Avatar
urine injection. lmfao.
Old 03-24-2009, 01:06 PM   #30
Build them right....Mod
philntx's Avatar
All Blazers made in Brazil come with a 2.4 Flex fuel engine or a 2.8 turbo Diesel
Old 03-24-2009, 01:24 PM   #31
ZQ8 Blazer
ZQ8 Blazer's Avatar
I thought they just had diesels, but I know you know what you're talking about so I'll take your word for it.
Old 03-24-2009, 01:31 PM   #32
Fronkensteen
The Griff's Avatar
The Pythagorean Theorem was one of the earliest theorems known to ancient civilizations. This famous theorem is named for the Greek mathematician and philosopher, Pythagoras. Pythagoras founded the Pythagorean School of Mathematics in Cortona, a Greek seaport in Southern Italy. He is credited with many contributions to mathematics although some of them may have actually been the work of his students.
The Pythagorean Theorem is Pythagoras' most famous mathematical contribution. According to legend, Pythagoras was so happy when he discovered the theorem that he offered a sacrifice of oxen. The later discovery that the square root of 2 is irrational and therefore, cannot be expressed as a ratio of two integers, greatly troubled Pythagoras and his followers. They were devout in their belief that any two lengths were integral multiples of some unit length. Many attempts were made to suppress the knowledge that the square root of 2 is irrational. It is even said that the man who divulged the secret was drowned at sea.
The Pythagorean Theorem is a statement about triangles containing a right angle. The Pythagorean Theorem states that:
"The area of the square built upon the hypotenuse of a right triangle is equal to the sum of the areas of the squares upon the remaining sides."
Old 03-27-2009, 04:51 PM   #33
So no.
How do you figure?
Old 03-28-2009, 03:23 AM   #34
Out Of Gas
BlazinDimes's Avatar
I love whore threads.
Urine Injection? Thats epic.
Old 04-10-2009, 08:39 PM   #35
takes 2 balls in our game
s10-den's Avatar
I had an 88 blazer 2.5 5 speed, wouldnt get out of its own way!
Old 06-28-2009, 09:57 PM   #36
High mileage
AustinBlazer's Avatar
I test drove a 1986 Blazer 4x4 with a 2.5/auto, a/c, ps...
I asked the seller if 0-60 was measured in DAYS...
Old 06-29-2009, 02:57 PM   #37
don
don's Avatar
2wd rodeos came with the 2.2 ...they shouldn't have but they did...lol
Old 06-29-2009, 03:32 PM   #38
Truckless Member
Old 06-29-2009, 03:40 PM   #39
94 2.2, feel the power?
deathphoenix99's Avatar
Too bad the S10's came with the 2.2, 4.3 FTMFW!
Old 06-29-2009, 05:26 PM   #40
FAHQANDFAHQ2
fahqandfahq2's Avatar
my Uncle had an 88 that had a 2.5 5 speed in it...had like 95hp or some shit...was a POS and god only knows why chevy would do such a horrible thing like that but they did...only thing that could fixed it was a hand grenade...haha
Old 06-29-2009, 06:21 PM   #41
Starting from scratch...
02_Black_XBlazer's Avatar
I use a throttle body spacer to pop out my door pins...
Old 06-29-2009, 09:09 PM   #42
FAHQANDFAHQ2
Quote: Originally Posted by roboticsguy
hah!...i seen my uncle dump the clutch on is and it just made a god aweful sound and pulled out...i just looked at him ashamed... lolol
Page generated in 0.78483 seconds with 31 queries
[Output: 199.08 Kb. compressed to 183.04 Kb. by saving 16.05 Kb. (8.06%)]
