LTinbettershapethanever
Hi Everyone,
I've been having this vibration for a long time in my 97 Blazer and no solution yet. When I hit a bump/pothole/bad road condition, I feel like the whole Blazer is shaking. You coud feel it in the console, seats, door panels, mirrors...... My first thought are those darn motor mounts. I think they are busted. Do those make such behavior? I have changed to Bilsteins and ever since the ride is much stiffer but you could feel the tires sticking to the road. I changed the links on the torsion bar mount and the rear axle. I also suspected tire pressure, and tried different settings to no use. Any help would be great. |
Re: Blazer vibrating on bumps
Anyone with a hint ?
Have you checked your body to frame mounts? Could be loose or the rubber bushings rotted thus allowing the body to flex a lot and move around
Rob |
Check your front wheels bearings. I just did that in mine (95) which had the right wheel bearing several turns untight
. Feel different now (left side was OK since the other day). |
Thank you for the ideas, will look into it. Is there a way to check the body mounts without taking them off?
