Well i took my moms blazer to 2 tranny shops today and both told me that it needs to be rebuilt. I dont have reverse 2nd or overdrive. im gonna just end up replacing it with a reman or used. My ? is what years will work best to do a swap into a 99 blazer with 4.3 auto(4l60e) 4wd? and anybody got a trans to get rid of that will work. im in the nj area and would like to pick up. thanks
Japan bound
Re: blazer tranny swap
i just did mine in my 98 blazer about a year and a half ago, they will work from 96 and newer. i got mine from a salvage yard and havent had any problems with it. hope this helps you out any.
Japan bound
and if you have any questions you can pm me, i did mine myself in my wifes familys driveway
nate98blazer...
is yours also 4wd? how long did the whole process take you? how much did u pay for the tranny if u dont mind sharing... i might be in the same ordeal shortly |
Japan bound
no, mines not a 4wd, it took me a weekend, i payed about 430 for it than i screwed up the front pump when i installed the torque converter and didnt feel like dropping it again, so, i took it to a tranny shop and had them install it for me. they charged me 250 if i remember correctly. but i actually had it installed and everything before i figured out the front pump was screwed up. the trannys are the same for 2 or 4wd, but i dont know how much more work is involved with the transfer case and all
No, they have different output shafts and the transfer case bolts to where the tailshaft housing is on the 2wd. |
Japan bound
