Blazer Leaking Need Help
I have an 01' S10 Blazer I just bought last week. Today my friend noticed water on the floor of the passenger seat. I lifted up the floor mat and it was soaked, and the water was hot. Is it my AC leaking? Is it a easy fix I could probably do myself? And if I took it to a shop how much do you think it should cost?
Thanks, -Jason |
It's 4:20 Somewhere!
Re: Blazer Leaking Need Help
sounds like the heater core. i have heard it is a real pain to replace.
Posts: n/a
could also just be the evaperator core plugged up and leaking onto the floor.... jack the truck up on the pass side as high as you can safely.... then take a coat hanger and run it up into the A/C evaperator drain tube (should be coming out of the firewall near the pass side... this will drain any water that was somehow plugged up in the tube....
if this is not the problem, then it might just be the heater core... you should have other symptoms though if it is a heater core like the water on the floor will be coolant, not water and the defroster may also fog up the inside of the windsheild. |
Slow Sonoma
Ticket Magnet
forum idiot
or... was it stinky if so it is your heater core... |
Slow Sonoma
Heater core was $38 and bought 3 gallons of pre-mixed antifreeze (no clue how much I actually need, they couldn't tell me). I would never have a shop work on something as I don't need to pay someone $90 an hour to do what I can do myself in half the time it takes them to. |
Ticket Magnet
Slow Sonoma
Ticket Magnet
Slow Sonoma
. I didn't even think to line those pipes with silicone.![]() |
Posts: n/a
heys im about to do the heater core in my truck also any pointers/ tips? how bad is it actually to pull the dash? thanks
Slow Sonoma
#1 tip: Remember where all the bolts are. Make sure to mark them or use some other method to remember where they go. I ended up with a handful of extra bolts...my dash is solid though so I'm not worried. |
Posts: n/a
thanks for the info. i did mine yesterday in 3.5 hours with hand tools. damn i wish i had a compressor though!! i only had 1 bolt letf over too. im proud of myself!! just think shops charge anywhere between $500-$700 to do this!!
