Blazer/Jimmy Hood help
Old 06-07-2007, 07:21 PM   #1
Insert Witty Comment Here
I found a hood that came off 99 Jimmy(or so it says online) I have a 99 Blazer. Will it fit just right? My assumption is that all S series viechles are pretty much the same. Am I correct? Will it fit and look like it should be there?(to the non S10 enthusiast)
Old 06-07-2007, 07:40 PM   #2
Enthusiast
BlazinImpact1017's Avatar
Re: Blazer/Jimmy Hood help
The hoods should "interchange", but the Jimmy hood has different "hood lines". The Jimmy has "hood lines" that start at the head lamps, regular Blazer just has the center "hood line". I am not sure if the "hood lines" will match up with the blazer head lamps. Take a look at this thread.... http://www.s10forum.com/forum/f136/n...blazer-298343/
Old 06-07-2007, 09:14 PM   #3
Thanks, I took a look at the thread, I think I will probably go for it.
Old 06-20-2007, 11:52 PM   #4
Earlier this year I put a 99 S10 hood and a 2000 Blazer, needed to work the gaps and adjust it a little, but dimensionally they are the same!
Old 06-25-2007, 01:53 AM   #5
96blazer's Avatar
The GMC hoods look nicer too.
Page generated in 0.56016 seconds with 31 queries
[Output: 52.77 Kb. compressed to 50.08 Kb. by saving 2.69 Kb. (5.10%)]
