it happens
blazer and trailer?
well we have a 26 or 28 foot camping trailer that weighs around 4500 pounds can i tow it okay? what will i need? i am getting a regular hitch oh and the trailer has electric brakes.
This is doo doo baby!
Re: blazer and trailer?
class 3 hitch 5000 lb.+ hitch ball
your gas mileage and power are going to go down the pooper but it should be able to stop pretty well with the electric brakes. Also the ass end is going to sag a little bit as well. |
Overhead Console Expert
a weight distribution hitch...and a bigger vehicle. thats over max for the s10's ...be real careful
it happens
The Dreamsicle
2wd or 4wd? towing package?
it happens
ZR2 member
from owners manual
4x4 2 door 5spd 3.42 gear max trailer wt 3,900lbs zr2 4600lbs 4x4 2dr 3.73 gear 4100lbs 4x4 4dr auto 5100lbs 4x4 4dr 5spd 3.42 gear 3600lbs |
it happens
yea stop raining, got my book and it says my blazer can haul 5,600 pounds |
have fun towing that much. i know for a fact a 26 or 28 foot trailer will nearly kill ur blazer. u will need a brake controller for ur blazer a weight distribution hitch set up correctly and alot of money for new brakes on ur blazer and a ton of cash for gas. 26 or 28 foot trailer is not a small trailer i wouldn't personally do it. i work around trailers for the past 3 years now. 2 1/2 years around rv trailers and 1 year now around car trailers.
first time i ever pulled my 25 foot box trailer i poped a break line make sure they are good and not rusted and the thread are good
We pull a 20ft trailer loaded with hay every 2 or 3 days with my stepmoms 4.3 4x4 4 door jimmy and it does pretty good. Somewhere around 6000 lbs without the trailer. Its made about 30 trips like that but the trans is about gone
it happens
well this is only going to be a 100 mile trip like 3 times a year not across the country, so i should be able to do it if i have pro setup
Registered (Ab) User
With a weight distributing hitch and electric trailer brakes, it should be a piece of cake. Take your time and don't push it too hard. The heaviest load will be on the tranny, so take off slow. I would also install an auxiliary tranny cooler - about $100 but money well spent.
With electric trailer brakes, it's almost like stopping without the trailer - very little load on your brakes. Be sure to air up your tires to the max - prolly 35 psi. Anticipate your stops. Watch out for that red light 1/4 mi. ahead and coast a lot. Be careful and have fun on your trip! ![]() |
have fun wiring that blazer for electric brakes if u need any help just pm me and i can give u a step by step how to do it. anticipate about a 3hr job for the first time ever doing it. i can normally at my job have a hard wire brake control done in under 1 1/2hrs.
it happens
k thanks i havn't decided if i am going to have my mech do it or do it myself |
it happens
where can i get the stuff i need? |
http://www.etrailer.com/pc-BC~5500.htm that is one of the easiest and best brake controller on the market. we sell at my job 99 percent of the time that controller. u will need 2 separate runs of power to the rear of the blazer. 2 runs 12 guage each. one is for brake feed to ur 7 way plug on the rear and the other is a hot wire if needed. everything else wire wise u can use 14 gauge would be plenty
it happens
i'd say after buying that brake controller expect to pay another 100-150
it happens
thats reasonable cause the hitch for ur blazer we sell at my job about 180 before tax. what kind of hitch is it class 3 or 2. make sure he knows exactly how to do the wiring.
I'm slap happy, bitches!
get rid of the trans PWM lockup control, or you will kill this thing the first time you pull uphill with anything under 98% tcc apply. a cooler wont do shit for you if you are still running pcm controlled part lockup.
it happens
yea he knows, the place is called tommys trailer and auto repair, and it is a class3 hitch he got at cost for 125 and he has the same brake controller for 50 at cost plus labor witch comes out to 200-250, i know this guy really well and he only charging me what he pays he will make his money on labor Last edited by chevyrules05 : 06-27-2008 at 10:12 PM. |
#24 |
it happens
#25 |
are u sure its that exact controller cause 50 bucks is extremely cheap.
#26 |
it happens
#27 |
shoot my job buys in bulk as well we bought like 5 or 6 boxes of those controllers and at cost which is what i can buy it at costs more than that.
#28 |
it happens
#29 |
so it is still digital readout or just a green dot?
#30 |
it happens
#31 |
ok show pics of the install if u don't mind and i'll help u out if i don't see something right.
#32 |
it happens
