Hello everyone, I need your help making a decision. I have a 1998 GMC Jimmy 2-door SLS with 132,000 miles on it. It's retail value is only $4,500. I have discovered the following problems with it and need to know if it is worth fixing, or if I should just get rid of it.
What do you think? Should I fix all of this or get rid of my Jimmy? |
TA / FSC Member
Re: Big problems, worth fixing?
I would fix it, Ive fixed much worse on my Blazer.
Do you like the Jimmy? If so then keep it if youre ready for a new car or truck ditch it or part it out. |
Banned
My tranny is going out in my Blazer. I'll drive it till it's junk....
Well the fuel pump just went out on me. I just got back from being towed home. So that will be fixed! It's one ****ing expensive repair! I HATE GM (but also love it so...)
V8 Member
look at it this way, once its repaired thou it wont have to get fixed for another 132k... just a thought. the oil lines arent hard to do yourself if you have a nice saturday, the patients, and the tools, do it yourself its only like 120 bucks at the most
the a/c system is a nice thing to have but dont need it to work to have on the road ya know, id fix the hub before anything else thou.. if ya love the blazer keep it.. i love my 2000 Jimmy |
And I have a question - if the oil lines are such a common problem with these vehicles, why hasn't someone made a third party replacement that doesn't break as easilly? Would that just make too much sense? |
V8 Member
oops sorry ment the cv shaft, not the wheel hub my bad, thou the hub do like to fail on these things too.
the oil lines that you can get thru napa are a lot better the the ac delco garbage ones, do up a search i did a quick write up on here on my project that i did for the jimmy. |
