bellhousing bolt
Old 09-24-2009, 06:45 PM   #1
Registered Idiot
84_sdime's Avatar
Exclamation bellhousing bolt
ive searched the forum. im taking out my 4.3 and i cant figure out how to the to the top left bellhousing blot, it looks impossible the body just curves right around it!
i know im not the only one whos had this problem.
Old 09-24-2009, 06:46 PM   #2
Fvck New Jersey
Tim99Zr2's Avatar
Re: bellhousing bolt
sorry i cant help, with my 2" bl it was easy to get to! haha
stubby ratchet wrench?
Old 09-24-2009, 06:56 PM   #3
Registered Idiot
84_sdime's Avatar
"ohh i have a body lift, im so cool, my names Scott Malkinsin" hahahaha jkjk
dammit tho....
Old 09-24-2009, 06:58 PM   #4
Fvck New Jersey
Tim99Zr2's Avatar
pull out your tranny xmember, and let your tranny hang, that may let you get it.
i member i also left my tranny hang under my truck by the motor, i had a ton more room.
and if that dont work, you could unbolt your rad support, and front 2 or 4 body mounts from your frame, and jack up your body.
Old 09-24-2009, 07:17 PM   #5
Registered Idiot
84_sdime's Avatar
that is so much work for 1 bolt... i cant believe its not a ford.
Old 09-25-2009, 01:31 AM   #6
95tahoelt's Avatar
the way to do it is to seperate the motor mounts. pull up on the engine with your hoist or picker. start shaking the engine chains until the engine starts to turn down on the drivers side. if you have a y pipe (cross over) you have to drop the hangers in front of the cat.once it turn a few degs set the engine back down. you should be able to get it with a 9/16's swivel cap socket and 18 inches of extensions.
Or you can do it like some i know drill a 1 inch hole thru the floor slash firewall.
Dont forget the 3 ground wirs on the back side of the heads or the tranny lines bolted to the side of the oil pan. (it sucks when you rip those out) lol
Old 09-26-2009, 06:10 AM   #7
Registered Idiot
84_sdime's Avatar
cool thanks, ill finally be able to get that bitch out! haha
Old 09-27-2009, 02:03 PM   #8
The Dreamsicle
cpolaris502's Avatar
Swivels are you friend, i havent done it before but thats what a friend used and said it saved him.
Old 09-27-2009, 02:28 PM   #9
95tahoelt's Avatar
you cant get it with a normal swivel behind a socket. you have to use a 9/16 swivel socket. we normally dont put that one back in on this application. it's right above the pin and there is a bolt 3 inch's below it.
Page generated in 0.78621 seconds with 31 queries
[Output: 67.28 Kb. compressed to 63.13 Kb. by saving 4.16 Kb. (6.18%)]
