Battery Light
Old 12-29-2008, 05:37 PM   #1
Registered Boozer
coloRADo_S10's Avatar
Exclamation Battery Light
Hey guys. My mom has a 2001 4dr blazer and she said her battery light came on randomly while she was driving. Does that mean the battery is dead? about to die? Alternator?
Anybody have a clue?
Old 12-29-2008, 06:00 PM   #2
Re: Battery Light
I dont know about the battery lites on our truck but i know when the battery light woould come on in my other car was when the alternator was dieing or the belt would be slipping so maybe the belt might be slipping just a guess im not sure but i hope this helps
Old 12-29-2008, 06:02 PM   #3
Registered Boozer
Re: Battery Light
Anything helps. Cuz the terminals are clean the batt is fairly new
(couple months) and the wires are fine.
Old 12-29-2008, 07:59 PM   #4
SmartTrak FTW
cpolaris502's Avatar
Re: Battery Light
I think it usually means that the alternator is starting to go or is gone. Like it is not recieving a charge, like when you have your key turned back and just the radio on i think the light comes on then.
Do you have any idea if the voltage meter dropped down while it was on?
Old 12-29-2008, 08:50 PM   #5
Shawn-GMC's Avatar
Re: Battery Light
alternator is going, happened to me on my truck and i replaced the batt and it just died few days later.
Old 12-30-2008, 12:16 AM   #6
Re: Battery Light
The light will illuminate if the PCM detects a voltage less than 12volts or greater than 16volts.
Old 12-30-2008, 12:29 AM   #7
Registered Boozer
Re: Battery Light
Thats what i figured! Thanks guys. I really appreciate it. You guys all rock!
Old 12-30-2008, 06:41 AM   #8
Captain DIY
D.T.'s Avatar
Re: Battery Light
I thought the light comes on if there is a voltage difference between the alternator output and the battery. If one is weak or low, the light illuminates. This is probably old school thinking though..
Check the voltmeter. I'd say it's the alternator also. Usually when I have one fail, it's the bearings, not the regulator/rectifier. They start to squeal or it just locks up and burns a belt. If the battery is going bad, it just doesn't want to turn over.
Old 12-30-2008, 07:57 AM   #9
Re: Battery Light
I'd have to say the first part is probably true. In my 96 I had an alternator go bad. It was putting out some voltage, but not enough to charge the battery and less than it took to run the vehicle. As I was on the road, you could see the guage slowly move from what I would guess to be about 13v slowly down to just above the red line. Pulled over, changed the alt and there was barely enough juice to crank the truck over (2 seconds at most) Voltage slowly increased and charged the battery. The light NEVER came on.
Old 12-30-2008, 11:50 AM   #10
Registered Boozer
Re: Battery Light
For an alternator to work/ do its job it needs to be putting out atleast 14v. I took out my handy dandy voltmeter and its running at 11.78v and thats not enough!At that voltage it will not recharge the battery.
I NEED A NEW ALTERNATOR!
So ill be calling around looking for the best prices. so far checker is the cheapest at 115 lifetime warranty. So do some more looking and ill buy one and put it in tonight!
Old 12-30-2008, 06:31 PM   #11
Re: Battery Light
I had a bat alternator it would not charge at idle but it would charge when the gas was going if you gave it gaas it would jump righ tup to above 14 but if it was just idling it would go down to like 11.5
but my light never came on from that problem
Old 12-31-2008, 03:34 AM   #12
Registered Boozer
Re: Battery Light
new alt in and light is off. problem solved!!!!!!!!!!!!
Old 12-31-2008, 11:02 AM   #13
Re: Battery Light
glad to hear it
