Batterie dies key wont come out
Old 09-01-2008, 04:39 PM   #1
Ok i am curiosue not sure if it is somthing to do with the security system that was put in the car a few years ago or if this is normal but when the battery dies completly it wont let me turn the key off and take it out is this noraml also it is like a lock out i cant shift it to nutral or anyting if the batt is dead
Old 09-01-2008, 05:42 PM   #2
Ticket Magnet
Rhotpursuit's Avatar
Re: Batterie dies key wont come out
Nothing to do with the aftermarket security...but it does need power to remove the key and put it in park.
Old 09-01-2008, 05:51 PM   #3
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
There is a small solenoid located by the key slot, it will pop in to allow you to remove the key and or get it into gear. you can remove the plastic and pop this by hand if you need too.
and yes that is normal haha
Old 09-01-2008, 06:05 PM   #4
i looked i could not find the solenoid maybe i didnt look hard enought will it be ontop or closer tords the bottom of the egnition ?
how come is this normal in all of GM
I have never had this problem with any of my livolns i have ever had
Old 09-01-2008, 06:07 PM   #5
~~<<' DRIVEN '>>~~
DJDAudio's Avatar
I can't remember the exact location,
But I found the problem in a 98 bravada
Old 09-05-2008, 01:46 PM   #6
Still fixing the Blazer
joshuaT's Avatar
My blazer does this too and takes forever for the key to be removed. Is it a hard fix to replace the whole ignition? It does this locking on both mine and my wifes key and we are finally tired of it.
Old 09-05-2008, 01:56 PM   #7
We had this problem with my girlfriend's grand am. Easiest solution is probably to jump it if you can.
Old 09-05-2008, 04:42 PM   #8
joshuaT's Avatar
Mine only happens when I go to turn off my blazer. Once the key is turned it locks itself in the keyhole and we have to keep twisting the key to get it out. Sometimes it takes one try then others the key stays in the blazer in my garage overnight and then just comes out.
Old 09-27-2008, 09:52 AM   #9
bubbaj71's Avatar
look just under the ignition, there's a small cap that needs to be removed then just push something like a toothpick in the hole to remove the key
Old 09-28-2008, 01:10 PM   #10
Registered (Ab) User
Yogi's Avatar
The only thing under mine is the bottom half of the steering column trim. Is the access hole underneath the trim piece?
Old 09-29-2008, 11:02 AM   #11
bubbaj71's Avatar
there's a circular piece right near the ignition, just pop it out
Old 09-29-2008, 12:24 PM   #12
Yogi's Avatar
I don't see anything like that on my '98 Blazer.
Old 09-29-2008, 12:49 PM   #13
Goran's Avatar
Bubba's right...
it's about 3/8" diameter, under the ignition... it's in there pretty good, you'll need a knife or something to pry the plug out...
here's a pic...
Old 09-29-2008, 01:38 PM   #14
Yogi's Avatar
Quote: Originally Posted by Goran
Bubba's right...
here's a pic...
I have the 2 holes under the center of the steering column but not the hole to the side under the ignition. Must be just on certain years.
Old 09-29-2008, 05:18 PM   #15
Goran's Avatar
that's from my 00 Envoy
Old 09-30-2008, 01:15 AM   #16
bubbaj71's Avatar
i have a 97 ls 4 door auto, your 98 has to have it
Old 09-30-2008, 10:13 AM   #17
Goran's Avatar
you have to pry the plug out... there won't just be a hole there...
if bubba's 97 has it, and my 00 has it, your 98 must have it...
get in there with a flashlight and look closer... you have to pry the plug out
Old 09-30-2008, 11:00 AM   #18
Lifts are for 4wds!
andysutt's Avatar
Never knew about that plug. I've got a 2000 Jimmy and a 97 Sonoma. I always hooked a battery charger up or jumped it. Now I know for next time. Thanks.
Old 09-30-2008, 12:35 PM   #19
Yogi's Avatar
Here is a pic of the column on my Blazer and I don't see a hole or a plug, except for the holes under the center of the column.
Old 09-30-2008, 01:55 PM   #20
bubbaj71's Avatar
WOW! slap me twice and call me stupid
Old 10-01-2008, 10:09 AM   #21
Goran's Avatar
Ditto
Old 10-01-2008, 10:27 AM   #22
Ticket Magnet
Old 10-01-2008, 10:28 AM   #23
Lifts are for 4wds!
andysutt's Avatar
Just went and checked... the 97 sonoma has it and the 2000 Jimmy... different shape plugs and in slightly different location but both have it
I wonder if it has to do w/ floor vs column shift
Old 10-01-2008, 10:57 AM   #24
Yogi's Avatar
Maybe it's because I have the tilt column?
Old 10-01-2008, 11:11 AM   #25
Lifts are for 4wds!
andysutt's Avatar
Both of mine have tilt columns, but they are floor shift
Old 10-01-2008, 01:36 PM   #26
My wifes Trailblazer does that stupid crap also! It's so stupid!
Old 10-01-2008, 01:38 PM   #27
Lifts are for 4wds!
andysutt's Avatar
Keep a good battery/alternator on the car and you won't have the problem
Old 10-01-2008, 09:24 PM   #28
bubbaj71's Avatar
i have a floor shift, good batt. , and good alt. and it still does it
Old 10-04-2008, 11:03 AM   #29
joshuaT's Avatar
I wish it was this simple. Brand new battery and rebuilt alternator and it still does it. I think there is something loose in the ignition key area.
Old 10-04-2008, 12:04 PM   #30
Lifts are for 4wds!
andysutt's Avatar
Could be. Never had the problem unless I go out to start it and it was dead. The 2000 Jimmy we have, doesnt get drove much so it drains the battery once in a while.
Mom did mention that yesterday when she drove it she had to "jiggled the damn steering wheel again to get the key to turn" lol
Old 11-20-2008, 10:37 PM   #31
has anyone figured out how to fix or replace the solenoid yet
Old 11-21-2008, 11:14 AM   #32
Yogi's Avatar
Only way that I know is to buy a new starter because it seems that they only come that way.
Rock Auto.com lists a solenoid but it is for a "gear reduction starter" whatever that means.
Old 11-21-2008, 05:46 PM   #33
Yogi's Avatar
OOPS! Wrong solenoid!
I'm getting my threads mixed up!
Old 11-24-2008, 10:56 PM   #34
anyone figure out how to fix or where to find the solenoid? instead of electrical tape
Page generated in 0.64401 seconds with 31 queries
[Output: 151.98 Kb. compressed to 138.91 Kb. by saving 13.06 Kb. (8.60%)]
