Auto dim mirror wiring Help? - S-10 Forum
post #1 of 7 Old 01-28-2010, 04:51 PM Thread Starter
User is: jjimmy is offline
I have a 2000 jimmy "SLE trim" 4dr 4wd. It has the regular rear view mirror, and I want to swap in an auto dim mirror. I bought one and dropped the center console yesterday, I was hopping to see a conector for the mirror, but there is none. I have the original pigtail for the mirror so I could splice it if I had to, but I would rather do it the right way.
My question is should there be a pigtail for the mirror from the overhead console? or was there a stand alone harness from the bcm to the mirror. Has anyone ever done this mod before if so could you help.
jjimmy is offline
post #2 of 7 Old 01-28-2010, 10:16 PM
94 s10 in progress
FxsX24's Avatar
User is: FxsX24 is offline
Re: Auto dim mirror wiring Help?
i think its just power, the sensor is on the front of the mirror
1999 SAAB 9-3 SE
1994 S-10 PROJECT TRUCK 283 TBI V8
2007 YAMAHA NYTRO
Originally Posted by 2002redSdime View Post
only the most hardcore minitruckers are from canada, cuz even their milk is bagged!!
FxsX24 is offline
post #3 of 7 Old 01-28-2010, 10:27 PM
Zeeke98's Avatar
User is: Zeeke98 is offline
3 or 4 wires depending on mirror but you only need two, power and ground. 3rd is for reverse light which turns off the auto dim while backing up and 4th if it has it is for the dimming outside mirrors that some Envoys and Bravadas had. I put one in my Sonoma. I need to get one for my Blazer but it doesn't even have map lights so I got no wiring there.
Wade
03 Chevy S10 Blazer 2 door 2wd Cherry Red Metallic, 3/3 Belltech drop, 18" Ridler 695 18x8 wheels with Pirelli 235/50/18 tires, SS mirrors, Bravada front clip, 6000K low/4300K high HIDs, smokey red tails, Spectre cold air intake, Hypertech programmer, Cherry Bomb turbo w/turndown, Envoy door panels and handles
02 Camaro SS SLP 345HP Black 6 speed T tops
85 Camaro IROC Z28 Silver 305 TPI Auto T tops
Zeeke98 is offline
post #4 of 7 Old 01-28-2010, 11:26 PM Thread Starter
Hears what I have found, the mirror is a gentex GNTX 187. there are 5 wires on the back pin 1-5
pin1 Brown 12v+ switched "ignition"
pin2 Black grnd
pin3 light Green back up light 12v input
pin4 grey 12v+ to auto dim outside mirror
pin5 pink 12v- to auto dim outside mirror
it seems the colors arnt that important its the pin # that tells you what should be there. I have not been able to find any mirror with the same color wires I have but all the 5 wire mirrors have the same pin out set up.
ill update this once I power up the mirror.
jjimmy is offline
post #5 of 7 Old 01-29-2010, 08:57 AM
Zeeke98's Avatar
Hmm...didn't remember there being 5 wires on mine. All you need really is power and ground. Technically it should be switched to your lights so the auto dim only comes on when you turn your headlights on. I think that's how it worked in my Jimmy. I just wired it to switched in my Sonoma though.
Wade
Zeeke98 is offline
post #6 of 7 Old 02-03-2010, 03:43 PM
jessejames1205's Avatar
User is: jessejames1205 is offline
I put an auto dim mirror in my 03 S-10 that did not have one before. I pulled an auto dim mirror from a 98 Blazer along with the whole harness for the overhead console and mirror. The harness runs from the console under the headliner to the driver sided A pillar down to where the fuse panel is on the Driver side of the dash and plugs into another harness at the firewall. It was just plug and play for me, it worked out great. I did not have to cut or rewire anything. Hope this helps.
post #7 of 7 Old 12-03-2010, 08:18 PM
vvolkswaggn's Avatar
User is: vvolkswaggn is offline
Question Re: Auto dim mirror wiring Help?
i picked up a windshield out of a local bone yard and it had a Metagal rearview mirror attached to it. I want to use it but not sure of what wire goes where i have 4 wires, white-yellow-orange-black- anyone have a clue? I'm putting this into a 98 s10 thanks!http://www.flickr.com/photos/volkswagenbus/5229786261/
