anyone have problems with wipers?
Old 02-19-2005, 07:46 PM   #1
rob619's Avatar
does anyone have problems with there wipers stopping for no reason ive checked everything from fuses to wires and everything is fine they willwork when they want to but then stop for a few minutes and then go again
Old 02-20-2005, 06:30 PM   #2
rob619's Avatar
Re: anyone have problems with wipers?
nevermind found it
Old 02-20-2005, 08:19 PM   #3
slowly, but surely.
sdime98's Avatar
yup...its typical
Old 02-21-2005, 11:28 AM   #4
[quote=rob619]does anyone have problems with there wipers stopping for no reason ive checked everything from fuses to wires and everything is fine they willwork when they want to but then stop for a few minutes and then go
yes we have, its the circut board located on the wiper board its self. you can buy them off ebay for 17.95. it will get to the point where they won't work at all.
Old 02-21-2005, 11:38 AM   #5
355 member
scrubz's Avatar
you know, I was driving to work this morning and for the first time they started stalling on the way down. I made them move my using the "mist" thing to where they only move once and they worked fine, and then shifted up to the normal speed and they worked fine again. Weird I thought but I hope it ain't serious
Old 02-21-2005, 08:06 PM   #6
When I was at the dealer they said there was a recall on some wiper part not sure what but they fixed the recall part
Old 02-22-2005, 11:40 AM   #7
Slap my meat on your pita
GeorgesBlazah's Avatar
its the wiper circut board. a guy on ebay sells replacement circut boards for like $25. i got one on mine and havent had any problems yet.
Old 02-24-2005, 01:32 PM   #8
rob619's Avatar
i just resoldered the one i have and works perfect now!!!!!
Old 02-26-2005, 01:35 AM   #9
andy84's Avatar
i have had a couple of times when i turn them on and they don't move. then i just reach out and tap them and then they work fine after that. do you think this is caused by the same circuit board thing?
Old 03-01-2005, 09:58 AM   #10
probably...when mine wouldnt work i usally popped the hood and punched the wiper box.
Old 03-08-2005, 04:15 PM   #11
Just re-solder the joints for the curcuit board connector (the connector that the cable harness plugs into) and save yourself a lot of money. I've fixed three of them this year alone by doing this. Only takes about 5 minutes to do.
Old 03-08-2005, 04:19 PM   #12
WillydaKid
Slow2.2S10's Avatar
my dad had a problem with that in his silverado, but his wasnt the circuit board. It was a build up of grime in the motor and wiper arms. Once it was cleaned they worked fine
Page generated in 0.58323 seconds with 31 queries
[Output: 75.92 Kb. compressed to 70.76 Kb. by saving 5.16 Kb. (6.80%)]
