Air Inflator won't turn on
Old 03-13-2005, 06:01 PM   #1
Did anyone ever have any problems with the built in air inflator in the back. Mine won't work and i can't figure out what fuse to check. Hopefully it is just a fuse and not the part itself
Old 03-15-2005, 01:18 AM   #2
Got keyless door handles?
XBLZR03's Avatar
Re: Air Inflator won't turn on
That must be special in the Diamond Edition, cause I dont have one.
Old 03-15-2005, 01:20 AM   #3
specializing in 98-up s10
s10warehouse's Avatar
it came on the envoy and diamond and the trali blazers in the 98-01 models.. is it not in your owners manual? i have a envoy owners manual i can look in at the shop?
Old 03-15-2005, 08:09 AM   #4
I looked and it just said to check the fuse or bring to the dealer, i can't figure out what fuse to check, its not listed anywhere that i can see.
Old 03-15-2005, 03:50 PM   #5
SteveI's Avatar
Check the fuse block under the hood on the driver's side.
Old 03-15-2005, 04:16 PM   #6
Any idea which fuse it is
Old 03-15-2005, 04:32 PM   #7
SteveI's Avatar
There should be a Map sticker on the inside of the lid.
Old 03-15-2005, 05:31 PM   #8
there is but none of them are marked inflator or air compressor, there is an accessory one that is a huge 30 amp, but it is not blown
Old 03-15-2005, 05:38 PM   #9
SteveI's Avatar
Isn't there one for air suspension?
Also, did you check the inside fuse block?
Old 03-15-2005, 05:42 PM   #10
would it be the same one as the air suspension, i think i remember seeing one for that
Old 03-15-2005, 05:46 PM   #11
SteveI's Avatar
I'm not for sure about that. I just remembered seeing one for it.
Old 03-15-2005, 07:38 PM   #12
i checked the one for load leveler and its fine. Does the truck need to be running for the compressor to run or doesn't it matter. I think this might be one for the dealer, i looked for any blown fuses but didn't see any.
Old 03-15-2005, 07:42 PM   #13
did you test all the fuse's its pretty easy with a test light sometimes they look good and can be bad also check the power back their ... if i can remember is'nt their a power out let back thier too? does it have power?
Old 03-15-2005, 07:53 PM   #14
That outlet is dead, but the others work fine, if you could tell me which fuse it definetly is i can swap it out, the big ole 30 amp fuse will require a trip to autozone though
Old 03-15-2005, 08:20 PM   #15
1gmc2nv's Avatar
A friend of mine who works at GM has told me that these vehicles with the air assist suspension in the rear (envoys, trailblazers, rainiers) are notorious for failing. Either the won't self-level on one side or either side.
I doubt it's a fuse or wiring issue. Could be a mechanical problem with the on-board compressor itself. Have the dealer check it out.
Old 03-15-2005, 08:22 PM   #16
i have a compressor or maybe two and a set of the shocks too!
Old 03-15-2005, 08:29 PM   #17
i could careless about the load leveling, it would be nice to have the accessory air compressor in the back though, but chances are they run off the same compressor, but it doesn't make any sense that the accessory outlet back there doesn't work either.
If its a large repair bill, i will live without it
Old 03-15-2005, 11:04 PM   #18
SteveI's Avatar
If the 12v plug is dead too it's gotta be a fuse. Did you try it with the key in the "run" position?
Old 03-15-2005, 11:12 PM   #19
i tried it in every position, i need a better repair manual for this thing, the haynes that i have doesn't include all the extra accessories in the diamond edition.
Old 03-16-2005, 02:27 PM   #20
XBLZR03's Avatar
I need to see some pics of the inflator.
Old 03-16-2005, 02:58 PM   #21
Stepsider
Slacker's Avatar
Just start tracing the wiring back until you find where the power stops.
Old 03-16-2005, 03:20 PM   #22
I hate to pop the panel off, those clips look like they are going to break if i take it off
Old 03-16-2005, 03:26 PM   #23
Yes that Sh Sh Shit
el camino ss's Avatar
comes with the territory start ripping
