I Need to Post More
Can a 2001 Blazer be set up with the Air Bar rear suspension. If so what kind of mods would need to be made so that the Air Bar could fit on it, and which kit would be used? Post pictures of Blazers on with the Air Bar suspension, and how it is set up. And any info you may have on them.
Thanx |
The Bowtie Brigade
Re: Air Bar on Blazer?
2 door or 4 door? 2wd or 4wd?
I Need to Post More
2 door... 2wd
The Bowtie Brigade
I dunno. Anybody know?
I also do not know and will second the question, "Does anybody know?"
The Bowtie Brigade
if I'm not mistaken, the rear frame of a Blazer is different from an S-10. But since the AirBar doesn't require notching, it may work. It depends on the clamshell bracket and the crossmember it bolts around.
It's 4:20 Somewhere!
I have been looking around to see if the AirBar would work. I also have a 2001 Blazer 2door 2wd. The only thing I have found to fit is the AirOver Leaf.
I was told when I asked about bagging my blazer was that it needs to be a weld on kit.
s-10 driving season!!!!!!
No, it will only work on the s10 pickup. Any kind of blazer setup will need to be custom, sorry blazer guys
The Bowtie Brigade
SFBD 4 door
Location: Columbia, Tenakey Location: Tupelo, Ms User is: OffLine |
i maybe a first gen blazer owner but i do know this all blazer frames are crooked so anything made for the trucks wont work for the blazer or at least be a bolt on my rear air bag set up is bags on axle with a custom 4 link and cross memeber i have a project thread if u wanna look but like i said im a first gen'r.
, ill make a project thread in the baggin section once i start |
I Need to Post More
Hey Guys... Thanks for the info... Will remember this later on...
F u c k Wyotech
yes the airbar could work if you are willing to do some fab work
the lower part will work as is if the distance b/w the front of the spring and the axle location pin is the same as an s10(not sure if it is or not the upper part of the airbar(the axle part) would have to have a special bracket made to work with the wishbone link, which a tube crossmember and link bar tabs would not be hard to fab up then the rear of it where the bags and shocks mount would have to be cut and fitted into the blazer frame like a separate crossmember here is a pic of the airbar on my s10 truck, and then the airrides site, it could be done if you have the skills to customize it and make it fit...kinda expensive to do so though, it would be cheaper to get a suicide doors kit that you already have to do some welding on...i think...depends on what you want to do with it http://ridetech.com/productinfo/imag...barproduct.jpg not the best pic i know, but its all i got http://streetsourcemag.com/uploads/Ownerprofiles/Stock%20Sucks/326200592211AM2731.jpg Last edited by baggedzq8 : 05-05-2007 at 06:48 PM. |
The Bowtie Brigade
i have a blazer 2dr 2wd layin frame on 20's, the rear frame is alot different then that of an s10, your best bet is to jump on suicide doors.com and order there blazer notch, mines was done before this was offered so mine is made of 2x4 box steel, i have a full custom, suicide doors triangulated 4 link, with a bag over axle system, its a bitch but it works, ill have picks up soon, its in the posses of gettin new rear tubbs, and tubbin the front for the 20" rims
This is doo doo baby!
ill have pics up of the four link and notch soon, im in the process of tubbin it for 20's the notch is bigg enought for 22's but the wheels i have dotn come in 22's so im stickin with 20's i should hav ethe pics up soon of the work to the front firwall and fram rails to lay out
finaly got pics still under construstion tho
![]() ![]() ![]() ![]() and the notch ![]() ![]() |
looks awsome ne pics of the tub in side???
