ac work
im replaceing the ac compressor cause the leak detector is coming out of the middle of the case. after this is done should i take it to a shop to have them refill the r134 or can i do it myself with the recharge kit like i have before to top it off.
Re: ac work
you really wanna take it somewhere to get it filled...cause you need to vacuum it down...hold that vacuum then check for leaks...then fill it to correct pressures...or else you are just causing more issues.
