A Couple more Envoy Questions...
My heated seat doesn't work, the passenger seat one does. Every once in a while i blow a fuse??? any ideas?
Load Leveling Compressor, Stopped running, fuse isn't blown. Is there a way to test the unit? Thanks, |
Re: A Couple more Envoy Questions...
The heating grid may be shorting out once in a while. You can disconnect it and take a ohm meter and read resistance. or continuity. If you have no continuity or resistance have someone sit in the truck or pile something heavy on the seat and see if its shorting out. it may just be intermittent so you may not find it. I think you can replace the heating grid.
Rob |
by any chance could it be something as simple as a bad ground?
