A/C taking a long time to cool?
Old 07-22-2004, 09:59 AM   #1
Question A/C taking a long time to cool?
Is there anything I can do to make the A/C blow colder air sooner? It takes a good 15 or so minutes before it starts blowing cold air comfortably, by that time I am already at my next destination. Is there something I can clean that may be dirty? I took it in to a mechanic and he said the system is fully charged and all the components are working.
Old 07-22-2004, 04:32 PM   #2
Re: A/C taking a long time to cool?
and the mechanic didn't even point you in the right direction as to what it could be?? The only thing I can think of is it would need to be re-charged, but i guess not.
Old 07-23-2004, 03:08 AM   #3
TO PUNISH & ENSLAVE
ZonaNoma's Avatar
jmhouston80,
I don't know what kind of weather you cats are getting in Houston, but I can surely bet it's hot! Not as hot as it is here, but I would recommend you take your truck to a better mechanic or to a shop that can physically show you the test(s) they are running and make sure there are no leaks and that your system has been charged properly.
My little Sonoma has great a/c and it takes just about 5 minutes to make me turn it down because I'm freezing my ass off.
I would get a second opinion.
~M~
Old 07-24-2004, 12:03 AM   #4
Layn Dime's Avatar
yeah i need to take mine in also not cool at all
Old 07-24-2004, 01:31 AM   #5
madme's Avatar
if that was mine i would run it for about 10 min then pop the hood and see if the compressor is running and see if its kicking on and off. could be low freeon or even too much freeon, that will cause the air comming out to be warmer or so the guy said that helped me out with my A\C trouble. the temp should drop about 30 degrees F or so what i am told.
Old 07-26-2004, 07:02 PM   #6
aztecaking100's Avatar
[quote=madme] could be low freeon or even too much freeon, that will cause the air comming out to be warmer QUOTE]
yeah i had a 96 s10 regular cab i purchased from the auction the idiot that had it before put way too much freon and it when i put the tester it was up at 140 psi took alot out and checked the fuses the ac was blown so i replaced it and it started working great
Page generated in 0.56431 seconds with 31 queries
[Output: 56.81 Kb. compressed to 53.78 Kb. by saving 3.03 Kb. (5.33%)]
