99 Blazer NO 4WD - S-10 Forum
post #1 of 8 Old 09-11-2007, 01:28 PM Thread Starter
User is: weatherdog is offline
Question 99 Blazer NO 4WD
99 Blazer, 90,000 miles. I have the transfer case that also has the AWD option. When I shift into 4 hi the light just blinks and no front axle engagement. When I shift into 4 lo, the t case goes into low range, the light blinks but no front axle engagement. When I shift into Auto 4 WD, the light just blinks and no front axle engagement. It seems that the t-case may be working but the front axle is not getting the message. Any help would be appreciated.
post #2 of 8 Old 09-11-2007, 01:29 PM
forum idiot
orangesonoma's Avatar
Re: 99 Blazer NO 4WD
the vacuum actuator is bad.. it is under the battery...
Brian
orangesonoma is offline
post #3 of 8 Old 09-11-2007, 06:22 PM
badSol's Avatar
User is: badSol is offline
Like Brian said, it's either a bad vacuum actuator, or the vacuum line has broken off (that's what happened on mine, I took my battery out and looked at the actuator, the vacuum line had broken right off the fitting at the firewall)
2000 Blazer LT 4x4 - Daily Driver
1999 Pontiac Trans Am - The beast (or soon to be)
Member of the Anti-Bag Coalition
"Bags are for groceries"
badSol is offline
post #4 of 8 Old 09-11-2007, 08:16 PM
forum idiot
yeah i forgot about that...that does happen too
Brian
post #5 of 8 Old 09-11-2007, 11:07 PM
badSol's Avatar
Yeah, I didn't check it first either, if I had I wouldn't have bothered to take the battery out and look at the actuator just to find out it was broken off at the firewall, lol
badSol is offline
post #6 of 8 Old 10-08-2007, 08:37 PM
User is: The_Shok is offline
came across this while doing a search on AWD and I know I might be bringing this back from the dead, but anyway weatherdog did you have it in neutral and rolling slowly when you tried to go into 4wd?
I ask because i had the same prob as you when I got mine and found out I shouldn't be in drive when making the switch.
I was originally NoS10Yet but my account got lost when the servers died.
1999 4.3 S10 with over 200k miles on it, retired from daily driver duty. Its a toy now (SOLD)
2010 Dodge Challenger SE Daily Driver
The_Shok is offline
post #7 of 8 Old 10-08-2007, 10:38 PM
Dime Freightlines
99Jimmy2D's Avatar
User is: 99Jimmy2D is offline
That's only necessary to go in to 4LO going from 2Hi to 4Hi can be done in drive while moving.
GM Truck owners come join. http://www.gmtruckforum.com
post #8 of 8 Old 10-09-2007, 06:49 PM
so driving in 2hi if I hit 4hi it should just pop in? I'll have to try that.
I've barely touched that button, and when I did I used the manual, I had to pull a tree and needed 4 lo
The_Shok is offline
