98+ jimmy/sonoma headlight question
on the set w/o fogs, what light goes in the bottom corner opposite the turn signal? thanks.
the one i just bought from someone on here is hacked that spot up and i've got no clue what goes there. |
Re: 98+ jimmy/sonoma headlight question
if I am picturing this right, it should be the highbeam.
CDN 2WD 2Gen 4-Door!
It is just an empty cavity...the previous owner most likely had put strobes or something into it.
so then, as we're looking at that passenger light...the bottom right corner doesn't have any bulb for it? what do you think i could use to seal it up since it's all open now?
I cut mine to fit the 880 fog light bulb
The bulb twists in just like the factory fogs. I made a template from the factory 880 fog hole used a drill and small file set to cut for the tabs. Put the bulb in and a slight turn locks the light just like the factory fogs. When I have time I will do a "how to" write up with pictures.
