98 blazer not starting after replacing...
Old 05-28-2009, 01:19 PM   #1
coil, cam pos sensor, ecm, and still no spark!!! please help!
Old 05-28-2009, 01:39 PM   #2
independent755's Avatar
Re: 98 blazer not starting after replacing...
cant really help you but you posted this is the 1st gen section .. you should probaby try 2nd gen or here
http://www.s10forum.com/forum/262ci-forum-4-3/
Old 05-28-2009, 03:15 PM   #3
Stealin JTC's sandwichs
MadMikeZ28's Avatar
Location: In jtc's basement eating the salami sandwich from his fridge
Ignition module???? Did you have a service engine light on at any time? Have you checked for codes?
The modules can be tested at most auto parts stores. It should be on the braket with the coil.
Also if that is not the issue check for power at the coil.
Old 05-28-2009, 11:36 PM   #4
ty independent755 vbmenu_register("postmenu_6296825", true); i was unsure what it falls under and to madmikez28 its not throwing n e codes and theres power getting to coil and ignition modual and i replaced all them plus the pick up under the distributor what sends the signal to all that the brain???? if that was bad wouldent that throw codes???
Old 05-29-2009, 01:15 AM   #5
1st Gen Mod
fetuss10's Avatar
moved
Page generated in 0.56339 seconds with 31 queries
[Output: 52.25 Kb. compressed to 49.58 Kb. by saving 2.67 Kb. (5.11%)]
