98 blaz multiple probs
Old 02-25-2006, 01:38 AM   #1
drag that shit
oops2low's Avatar
well i was wonderin if anyone else has had any of these probs with there 98 blazers? well #1 my wipers have a mind of there own, they shut off whenever they wantafter i turn them on. #2 my gas gauge bounces from E to 1/4. an now #3 i think this one has to do with the brakes. it sounds like the relay for the turn singnals when they are on. but when i put very little preasure to the break pedal it stops. if anyone has any info that might help me i would greatly appreaciate it.
Old 02-25-2006, 06:43 PM   #2
Re: 98 blaz multiple probs
I had problems with my wipers also. Check and see if wiring is clip where it connects is locked in tight. My gas gauge does the same thing also.
Old 02-26-2006, 12:19 PM   #3
Canadian Dictatorship
Holeshot's Avatar
The wiper problem is very common........so much that I think Chevrolet should have released a fix for it.
The control board is shot, I've replaced mine twice.
Old 02-26-2006, 12:22 PM   #4
The fuel gauge could be a bad sending unit or a slosh module. You will have to do some cheking to find out which one.
Old 02-27-2006, 01:39 PM   #5
GMC - Professional Grade
blazercrazed's Avatar
I had the same brake/signal problem in my 99 c/k 3500 your describing. The truck actually wouldent start unless the brake was depressed??? HAHA. We still havent figured out what the problem is, just thought ide let you know you arent the only one with a possesed rig :-P
Old 02-27-2006, 03:30 PM   #6
bangin Woofenhogens
rangers had a similar wiper problem, and it was the MFS multifunction switch inside the steering column, excessive grease and it was causing ti to short out, just had to pull it and clean it. Maybe a place to check?
Old 02-27-2006, 03:39 PM   #7
Give me 3 yrs...
JollyRojer's Avatar
the guage sounds like its ur sending unit for sure, my first gen blazer does it
Old 03-06-2006, 02:26 PM   #8
i have the wiper demon in my 98 blazer too... its especially nice in the middle of a rain storm.. some times it acts up, other times you have no problem for months.. weird..
Old 03-07-2006, 07:51 PM   #9
loadedm16's Avatar
That happened to me once too. cept i was driving kinda close behind some lady and my wipers decided to stop working while it was pooring out. ended up rearending her and cost me about 700 bucks. I ended up replacing the motor about 8 months ago and it has not acted up since.
I also suffer from the problem with the signal sound. it always sounds like its on when its not. Itook it to a mechanic who is a family friend and he said its common on blazer and its most likely the switch for the turn signals. ive yet to fix mine but hope that helps.
Page generated in 0.62650 seconds with 31 queries
[Output: 66.63 Kb. compressed to 62.52 Kb. by saving 4.11 Kb. (6.17%)]
