96 blazer weird fuel problem
well first off i'm new to the whole blazer deal i've been a jeep guy my whole life but i got a good deal on a blazer i've read all the threads concerning this issue, if the truck sits over night it won't start without starting fluid so i checked the fuel pressure it was 59-60 psi but after the pump shuts off it drops about 4 psi haynes says fuel pressure should be within 55 to 61 psi so its well within limits, let it sit overnight it has 0 psi in the morning so i changed out the fpr now if i crank it like 4 or 5 times it will start as it didn't before, then when it does start it runs out awesome i am really lost on this one any ideas would be appreciated i don't want to waste 250 and my time if the fuel pump isn't the culprit thank you
Re: 96 blazer weird fuel problem
replace the fuel pump the fuel pressure shouldnt drop to 4 after the pump shuts off
Ditto on the fuel pump.
thanks guys i'll change the pump tomorrow
replaced the fuel pump today truck started right up and ran good thanks again guys
