5 Speed Rumors...
I have heard 3 things multiple time that involve 5 speed s10s, blazers. one being that they all had a cast iron fron dif. two beinf the rear axle is the "same" as a zr2 and 3 that the gearing is always 3.43. Is there anyone tht has the glove box codes so i can look it up or can just tell me which rumors are true and which ones arent? yes i did search ad got nuthin so dont flame.
Re: 5 Speed Rumors...
Off the top of my head GU6 is for 3:42's, dont know the others though.
theres a post on the 2.2 2nd gen forums for the rear axle codes not sure if they work for the 4x4 or not...
Build them right....Mod
RPO codes for rear axle ratios are the same across all S/T models
There isn't a separate RPO code for aluminum/iron front differential. However, I have only seen an Iron case front differential under a 5 speed Gen 2 Blazer, not an automatic Blazer. Last edited by philntx : 10-31-2009 at 10:39 PM. |
The Dreamsicle
My 2dr 2wd 5sp has an 8.5" rear end with 3.42s
no longer has a 95
thats a myth that all 5-speed 4wds had the cast iron front diff, my 95 was aluminum
S not all had them but it is possible right? and is there a code/design feature that would help me identify it?
no longer has a 95
crawl underneath with a magnet and see if it sticks
workin it !
great idea !
I will be 10% honest and say i never thought of that
Are there any codes to verify the rear end size or no? |
Need LSx swap.....
GU6 is a 3.42, G80 is govloc. i dont believe there is an RPO for the 8.5 rear, youd just have to look at it. and yes try the magnet method on the front, but i thought that the iron front diffs were black in color.
Black as in color/paint/powdercoat? And i noticed that the dome overide thing (press it a certain amount of times and the running lights go out) doesnt work but it didnt work on my friends 98 5 speed pick up when he had it. Is this common thru all the 5 speeds?
Need LSx swap.....
black as in paint i think, otherwise they would all be rusty within a few miles. ive never seen an iron one in person as mine is aluminum so i really cant say for sure. the dome override trick didnt work in my 99 but it did in my 2000, so i dont know what to tell you there lol
Slap my meat on your pita
The dome override works on 2000+. Also im pretty sure youll find Iron Cases on the awd Bravadas and most fo the time they should be on the Autotrac trucks as well.
I have only seen iron diff on 5-speeds.
I bought a junk bravada diff for the shaft and it was aluminum, as with most autotracs too. And the 8.5 axle was on some non Z's too. |
Dain Bramaged
Auto-trac here and my front diff is definitely aluminum.
Need LSx swap.....
yea mine 99 is an autotrac and its aluminum, i think my 00 NP1 is aluminum too. both autos obviously.
i thought all ZR2's had 8.5 rears? was it only certain years and up? |
If someone with a 8.5 rear can get me all their codes I will find out what one is 8.5, its hard looking threw all of them though, my list has every RPO code ever used on any vehicle, so its extremely long.
I can do the same thing for someone with a iron front diff, the only thing I found interesting so far, other than front axle GVW and ratios, is FE8-FRT DIFF CARR DR AXLE. Last edited by Drumer919 : 11-04-2009 at 03:44 PM. |
Yes all ZR2's had the 8.5/8.6 rear end.
But some non Z got it too. |
1998 blazer 5 speed 3.42, cast iron dif
So today i had my truck out and i did the magnet test and it stuck so it looks like i got the iron front diff lol and ik for a fact i got the 8.5 rear so looks like is got a pretty good setup from the factory
Registered loser
2000 Blazer LS 4x4 2dr. 5-spd
-Cast iron front diff. 3.42s -8.5 rear diff 3.42s and G80. -press the dome override X4 and the lights go out, press X4 again and they go back on. Just wanted to add my 2 cents |
