4x4 promblems
Old 08-15-2008, 03:39 AM   #1
Question 4x4 promblems
ive got a 01 blazer ls and my 4 wheel drive isnt working. When i go to engage the 4 wheel i hear the electic motor working but it doesnt spin the front tires and when i engage the 4 low i feel it clunck into 4 wheel but still the front tires dont spin any ideas on wtf that might be?
Old 08-15-2008, 12:09 PM   #2
Re: 4x4 promblems
do you here a click from passenger side floor board? does you actuator under the battier hold a vacuum? are there holes in your lines? are the fuses good? those are good thing to start to check first.
but from what i gather it will not stay in 4wd. that is a big thing around. search it . and if your search does not turn up any thing search on google
hope any of this helps
Old 08-15-2008, 09:16 PM   #3
Overhead Console Expert
raven2510's Avatar
Re: 4x4 promblems
yea its deff. the vacuum actuator....i guarantee it.
here's a good place to buy it to fix'er right up..
http://www.shop.synergyoffroad.com/p...5&productId=74
its mounted under the battery tray.
Old 08-16-2008, 04:12 AM   #4
Re: 4x4 promblems
cool thats a huge start but i was messin around with it today and it was engaging some times but not all the time so i think it is a vacuum leak ill crall under it and check the lines
Old 08-16-2008, 11:58 AM   #5
raven2510's Avatar
Re: 4x4 promblems
no you don't need to crawl under...remove battery, battery tray and its on the left....a vacuum line leads to it...see if the rubber is tore. if so replace it...if not still replace it...they have a habit of failing when you need it most
Old 08-16-2008, 11:59 AM   #6
raven2510's Avatar
Re: 4x4 promblems
Old 08-17-2008, 10:26 AM   #7
Re: 4x4 promblems
alright ill start that today im hope thats what it is thanks for the info
Old 08-17-2008, 06:41 PM   #8
raven2510's Avatar
Re: 4x4 promblems
yea....hope it solves ur problem
Old 08-18-2008, 12:18 AM   #9
Re: 4x4 promblems
thanks man that was the problem little hole in the line
Old 08-18-2008, 07:42 PM   #10
raven2510's Avatar
Re: 4x4 promblems
cool....so i assume you fixed it?
Old 08-26-2008, 12:55 AM   #11
Re: 4x4 promblems
yeah there was some lines ripped apart from dry rot now its cruzin through mud
Page generated in 0.57467 seconds with 31 queries
[Output: 71.40 Kb. compressed to 66.64 Kb. by saving 4.76 Kb. (6.66%)]
