4x4 problem
Whenever i push 4Low all that happens is the light keeps blinking, but i dont think its engaging.. What could be the problem? or is this common? its a 2002 jimmy
Megabyte
Re: 4x4 problem
Drive your truck under 5 mph out, just get it rolling. Then put it in neutral. Then try engaging your 4x4.
Re: 4x4 problem
does 4hi work ok
Re: 4x4 problem
don't screw with 4 low...
you can do some serious damage... this is how i busted my rear end... attempted pulling a bush out in 4 low... i busted a 10,000 lb winch strap and this is what my rear diff looked like afterwards... ![]() |
Re: 4x4 problem
sweeet
Re: 4x4 problem
but when it happened it was ![]() |
Re: 4x4 problem
yes 4 hi works same with auto 4wd, just 4lo just blinks
Re: 4x4 problem
did you read the manual?
i think it has to be in 4 high, then put it in 4 low... might have to be in Neutral or have the car moving under 3mph or something... |
Re: 4x4 problem
fixed haha put in neutral n 4 lo works now
thanks guys! |
